Hard start
Old Feb 22, 2007 | 02:25 PM
B16b-EJ8's Avatar
Default Hard start
Hey guys,
Im having power issues that i believe to be related to either my stereo or alarm...a changed the alternator and tested the battery which is fine. Alternator charges the battery to 28ish volts but when i go to start my car it struggles to start if left off for a while. when i go to start my car i can hear the amp clicking on and off while the car is cranking...if i cut the power to the stereo the car will finally start. So im not sure what is draining the battery while its parked. The alarm is a cheap pretty much factory alarm using the factory horn so i dont htink its that. Any ideas on what to check. I have a kenwood 4 channel amp powering my speakers components up fornt and 6x9's in the rear, 4 gauge wire from the battery to a fuse to the amp...
Old Feb 22, 2007 | 02:41 PM
EBP_SI's Avatar
Default Re: Hard start (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys,
Alternator charges the battery to 28ish volts </TD></TR></TABLE>
are you sure about that one?
Old Feb 22, 2007 | 02:56 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Hard start (EBP_SI)
If your alternator is throwing out 28 volts your battery has been overcharged and might have a bad cell. How are the battery connections and grounds on the battery and tranny.
Old Feb 22, 2007 | 03:02 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Alternator charges the battery to 28ish volts </TD></TR></TABLE>
Ummmm.... Really?? Bad rectifier/voltage regulator??
Old Feb 22, 2007 | 04:05 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure about that one?</TD></TR></TABLE>
My bad had the meter on the wrong setting
Old Feb 22, 2007 | 04:06 PM
B16b-EJ8's Avatar
Default Re: Hard start (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">If your alternator is throwing out 28 volts your battery has been overcharged and might have a bad cell. How are the battery connections and grounds on the battery and tranny.</TD></TR></TABLE>
All grounds are good
Old Feb 22, 2007 | 04:41 PM
fcm's Avatar
fcm
Old Fart
I think you answered your ON question... "if i cut the power to the stereo the car will finally start" my guess would be it has something to do with the stereo. 94
Old Feb 23, 2007 | 08:21 AM
B16b-EJ8's Avatar
Default Re: Hard start (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> I think you answered your ON question... "if i cut the power to the stereo the car will finally start" my guess would be it has something to do with the stereo. 94</TD></TR></TABLE>
Well that would have been nice...i pulled the fuse to the stereo last night and well it was tough starting this morning...only thing i had on was the alarm....so now its parked outside of work with no alarm on...we will see what happens when i go to lunch....could it possibly be the battery? I hate to keep throwing parts at it...with the volt meter last night after driving home from work with the car off it was between 12-13 car on is was about 14 ish. Thanks for you help guys
Old Feb 23, 2007 | 08:36 AM
B18C_EJ8's Avatar
I guess we were all concentrating on your 28v situation and overlooked an obvious question... Exactly how old is your battery?
jdm.swift
Aug 15, 2010 07:54 AM
jdm.swift
Audio / Security / Video
Aug 13, 2010 06:56 PM
old-sk0ol
Nov 26, 2008 09:57 AM
94jdmdb8
Aug 30, 2008 08:56 AM
i
Nov 21, 2003 11:37 AM
