Grounding or bad amp?
Old Mar 12, 2009 | 06:25 PM
06typeSEX's Avatar
Default Grounding or bad amp?
Well i have a 00 Accord coupe, Amp power on but has red light("safelight") try switching around ground cable on every metal screw but no luck.... what can it be?
Old Mar 13, 2009 | 10:21 AM
audioroach's Avatar
Default Re: Grounding or bad amp?
try this
take the "load' off the amp (no speakers connected)
pull main fuse...wait a 1 then replace
turn on system
If light goes out...your speaker load is below what the amp can safely handle.
if light is still on..its toast.
I wish you luck
Old Mar 13, 2009 | 12:50 PM
King James's Avatar
New User
yeah i would say it sounds blown
what kind of amp is it and whats hooked up to it
Old Mar 13, 2009 | 05:23 PM
mrdeadman's Avatar
They let me pick
Not necessarily.
Do what audioroach said. Don't connect the load back though, turn it on first.
Old Mar 14, 2009 | 11:29 AM
ken9's Avatar
I cannot tell exactly what the problem is. It a problem in general. What kind of amp is it? Where did you ground your amp? Is the amp new, refurbish, second handed users?
Old Mar 16, 2009 | 12:11 PM
06typeSEX's Avatar
Its a MTX Jackhammer 300watts hook up to a 12' mtx sub.. headunit pioneer. Yes, I am a secound owner previous show me it work. I ground it under the seat belt bolt.
Another question guys do i really need to hook-up the remote(blue wire) to the amp?
Old Mar 16, 2009 | 12:51 PM
jdmcivicracer89's Avatar
yes u need to hook up the blue wire. the amp dosent work without it.
Old Mar 16, 2009 | 01:14 PM
infinitypro12's Avatar
That's the remote wire if I'm not mistaken. But yeah, hook it up.
Old Mar 16, 2009 | 04:52 PM
06typeSEX's Avatar
LMAO!!! I unhook it. Im gonna go at tonight.
Old Mar 17, 2009 | 07:08 PM
06typeSEX's Avatar
Thanks all.. system is working fine maybe alittle to loud lol but all is good thanks to you guys!
headrec*
Audio / Security / Video
Nov 17, 2010 05:17 PM
Built B16A
Mar 3, 2009 12:21 PM
TeenyTymer69er
14
May 29, 2006 07:32 AM
special_edition
Feb 3, 2004 03:31 PM
Feuerraeder
Dec 24, 2002 09:06 AM
