good spot in firewall???
Old Sep 17, 2004 | 03:20 PM
sicivic's Avatar
Default good spot in firewall???
Does anyone have any suggestions on a good spot on the firewall to run some 8-gauge wiring for a sub on a 95 Accord coupe?
Old Sep 17, 2004 | 04:10 PM
Goatsterrman's Avatar
Default Re: good spot in firewall??? (sicivic)
Is it a stick or auto? If it's an auto you should have a rubber plug where the clutch pedal would go through on a stick, you can go through it, not 100% sure, but it should be there.
Old Sep 17, 2004 | 04:14 PM
sicivic's Avatar
Default Re: good spot in firewall??? (Goatsterrman)
nope, the car is a manual
Old Sep 17, 2004 | 06:03 PM
lgbr's Avatar
On my 94 Civic, above the accelerator is a round rubber piece, you can easily pull that off, and push the wire through, then pull on it from behind the accelerator.
Other than that, I know on some cars you can find holes around the master cylinder, and if you need to, just drill a hole.
Old Sep 17, 2004 | 09:00 PM
cd5_2NR's Avatar
driver side by the pedals somewhere...and behind the glove box...works all the time
Old Sep 18, 2004 | 08:54 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicivic &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have any suggestions on a good spot on the firewall to run some 8-gauge wiring for a sub on a 95 Accord coupe?</TD></TR></TABLE> Pass.side firewall, should be some unused holes with rubber dummy plugs in them. 94
Old Sep 19, 2004 | 08:51 AM
Honda97's Avatar
on the driver side under the hood there is this big black rubber that some other wires go to your steering, fuse box, etc. I have ran a 8 gauge wire (**** ive run a 4 gauge wire) through this firewall in a accord before and it looks very professionally installed.
Old Sep 19, 2004 | 08:53 AM
Honda97's Avatar
Default Re: good spot in firewall??? (Honda97)
oh and DO NOT run your power wire with any other wires. you will get engine noise and it will be very annoying. run your power by the drivers side and the rca, remote, etc run it by the passenger side. This is if you are going to run it under the door moldings. if you are going to run the wires from the center just run your power from driver and the rest from whereever u want
Adnneby Reynoso
Jan 28, 2016 02:42 PM
bloodyknuckledad
Dec 11, 2010 01:18 PM
jaykav99
Audio / Security / Video
Jun 18, 2006 02:40 PM
deeekaay
Aug 19, 2004 04:55 AM
94accordsir
Dec 27, 2003 07:42 PM
