Need help cracking through firewall
Old Jun 17, 2006 | 10:09 AM
jaykav99's Avatar
Default Need help cracking through firewall
I have a 2006 Accord LX and want to reinstall my sound system. But i can't see really anywhere safe to crack into the engine comparment for the main power wire. Any help would be appreciated.
Old Jun 17, 2006 | 04:38 PM
JSPECSIR's Avatar
Default Re: Need help cracking through firewall (jaykav99)
if its an auto tran. you can drill throught the spot where the manual tran. master cylinder goes through at.
Old Jun 17, 2006 | 06:43 PM
siggy833's Avatar
Default Re: Need help cracking through firewall (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">if its an auto tran. you can drill throught the spot where the manual tran. master cylinder goes through at.</TD></TR></TABLE>
It's called the Clutch Plate. Drill through that and slap a grommet plug in there and your set...Dude if you can't figure this out than you shouldn't be workin' on your own car...
No really though it should not be that much of an issue..
Old Jun 17, 2006 | 08:16 PM
imadigitalgod's Avatar
Default Re: Need help cracking through firewall (siggy833)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siggy833 &raquo;</TD></TR><TR><TD CLASS="quote">Dude if you can't figure this out than you shouldn't be workin' on your own car...
No really though it should not be that much of an issue.. </TD></TR></TABLE>
Old Jun 18, 2006 | 02:13 PM
Kavehman's Avatar
Actually on an Accord its harder than you think to get wires into the cabin without drilling.
If my memory is correct there should be a predrilled hole near the drivers footwell for you to get that wire through.
It is a bitch though and took me a while to do, youll have to pull back the carpet and try and get it.
I reccomend drilling as a last resort
Old Jun 18, 2006 | 02:34 PM
suspendedHatch's Avatar
Default Re: (Kavehman)
Uni bit. Unit bit on an extension.
Old Jun 18, 2006 | 02:40 PM
jaykav99's Avatar
Thanks Kavehman ill check under the carpet. And to the other guys its a manual trans no gromets holes at all for wiring or anything else that i can get to and at the moment i rather not drill or pay someone to just run a power wire.
Day-DayC
Transmission & Drivetrain
Mar 12, 2012 06:45 AM
akces
Mar 16, 2010 09:25 PM
KillaEj1
Jan 15, 2009 05:54 AM
puertoroc7976
Nov 4, 2006 09:25 AM
