is this a good place? SHOCK SENSOR
Old Jan 26, 2005 | 05:22 PM
DC2 to AP2's Avatar
Default is this a good place? SHOCK SENSOR
will im finishing up installing my alarm (compustar 2W900) and was curious as to what you guys think of where i mounted the shock sensor. in the manual it doesnt give a specific location where to mount it and i know most shock sensor is mounted on the ignition wire harness. will this work? pros/cons?
in the middle of the car below the abs box.
Old Jan 26, 2005 | 08:33 PM
sdinteg's Avatar
Default Re: is this a good place? SHOCK SENSOR (imola-red dc2)
Anywhere solid to pick up the vibration works fine. The place you mentioned will work fine, but most of the installations I see are strapped tightly to the steering column. It doesn't have to be hidden or hard to get to, just secure!
Old Jan 26, 2005 | 08:44 PM
DC2 to AP2's Avatar
Default Re: is this a good place? SHOCK SENSOR (sdinteg)
yeah mine is screwed down and pretty secure.
Old Jan 26, 2005 | 11:09 PM
EGPrelude's Avatar
is that screwed down directly to the metal?
i dont know if this applies to the compustar shock sensor (i would think the concept would be the same for all shock sensors) but for DEI installations, its recommended that it be tired to a wire harness or attached to a plastic panel. It is not recommended that it be screwed to metal.
"..tying the sensor to a steering column or screwing it to metal will result in poor sensitivity..." - DEI
Old Jan 27, 2005 | 06:48 AM
t0p_sh0tta's Avatar
Default Re: (LSVTEC_DC2R)
Yes but no point IMO. A properly installed/functioning shock sensor will perform the same job as 2.
Old Jan 27, 2005 | 07:37 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">will im finishing up installing my alarm (compustar 2W900) and was curious as to what you guys think of where i mounted the shock sensor. in the manual it doesnt give a specific location where to mount it and i know most shock sensor is mounted on the ignition wire harness. will this work? pros/cons?
</TD></TR></TABLE>Yes that is a good spot for the compustar shock sen, I find they work best mounted to a flat solid surface as close to middle of car as possable 94
candyman206
Audio / Security / Video
29
Oct 6, 2009 02:27 PM
dxhatch93
Mar 16, 2006 03:41 PM
Setsuna F Seiei
Jan 26, 2005 09:30 AM
phayzeone
13
Nov 12, 2004 01:03 AM
icedaccord19
Feb 6, 2004 08:28 AM
