front speakers went out. help please.
Old Feb 11, 2008 | 03:18 PM
PurplePill's Avatar
Default front speakers went out. help please.
hey guys, my front speakers just stopped working. They were playing fine and then all of sudden the sound was cut off. What should i check first? the wiring to the headunit? wiring to the speakers? Both left and right front speakers went out at the same time. Anyone have any ideas? thanks.
Old Feb 11, 2008 | 04:05 PM
l337m4n's Avatar
Default Re: front speakers went out. help please. (PurplePill)
Do you have back ones too?Check the wiring, if you only have fronts check the antenna.Same thing happened to me.
Old Feb 11, 2008 | 07:42 PM
fcm's Avatar
fcm
Old Fart
Need a lot more info to start making a guess...
Start by telling us the MM&Y of your car.
Then makes and models of the audio system, what HU, [head Unit], what speakers, what amps if any and what speakers are the amps driving. 94
Old Feb 12, 2008 | 09:14 AM
PurplePill's Avatar
Default Re: front speakers went out. help please. (fcm)
I drive a 99 ek hatch. My headunit is an alpine cda-7893. I do have rear speakers and they work as of right now. My front speakers are alpine type r's. Rear speakers and my sub are connected to an amp but the front speakers aren't. Front speakers are just connected to the headunit. I have a 12inch type r sub by the way, and that is working just fine.
Old Feb 12, 2008 | 11:23 AM
White Smoke's Avatar
i my honda
Global Mod
1- Obviously, make sure your fader is setup properly.
2- Try resetting the HU by disconnecting the battery for a moment or two.
3- Make sure (if there is a setting for it) that the HU's internal amp is on.
4- Check the fuses in the back on the HU. Often times there is more then one.
You can try hooking one speaker up to the HU at a time to see if you can get one working. You can also try using the rear outputs on the HU for the front speakers.
If you can get one speaker working... Take a volt meter and check continuity between all four of the speaker wires individually and ground to ensure none of them are grounding out. You can also measure resistance of the + and - of each speaker and makre sure there the same.
Old Feb 12, 2008 | 04:22 PM
fcm's Avatar
fcm
Old Fart
An Alpine CDA-7893 , very nice, I have the CDA-7892.
As White Smoke suggests, make sure internal amp is on, [PWR-IC ON].
Press the SETUP button for at least 3 sec., then use the << >> buttons to select PWR-IC, then press BAND button to toggle between off and on.
Do you still have the owners guide for that HU, do you know all the features that HU has? 94
Old Feb 12, 2008 | 10:00 PM
PurplePill's Avatar
yeah the pwr-ic was off. i guess i accidently turned it off somehow. Thanks guys. Yeah i still have the manual for the HU. I think i know most of the features. Maybe not all though.
Old Feb 13, 2008 | 06:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: (PurplePill)
Hint, "amplify" the front speakers and drive the rear speakers off the HU, it will make setting up the staging and imaging of the system. 94
toshko321
Audio / Security / Video
Jun 16, 2011 08:34 AM
JDMB20TDA
Oct 7, 2009 04:26 PM
Cody2289
14
Feb 11, 2008 09:28 AM
TheTealHatch
23
Oct 11, 2006 08:05 PM
