Front Drivers Side Speaker not working?
Old May 11, 2009 | 08:18 AM
EK Domo-Kun's Avatar
Default Front Drivers Side Speaker not working?
Hey guys im trying to figure out what the problem may be with my front speaker, it didnt work at all so i took it out to test it to see if i needed a new speaker but it did work so im just wondering since i dont know much about this what could the problem be?
Thanks.
Old May 11, 2009 | 09:34 AM
twentyhurtz's Avatar
Default Re: Front Drivers Side Speaker not working?
you will need to provide more information, factory head unit? aftermarket? external amp?
Old May 11, 2009 | 11:25 AM
zsudz922's Avatar
check for continuity for those speaker wires.
Old May 11, 2009 | 03:10 PM
98civdx's Avatar
Master Detailer
you took the speaker out tested it??
did you hook it up to the other side that works?
Old May 13, 2009 | 07:18 AM
I took it out and tested it with my stereo in my house and the speaker works. Aftermarket head unit (pioneer), external amp (alpine) im not sure which one it is but its a smaller one.
I havent checked the continuity of the speaker wires but ill definately check that tonight, Thanks.
Old May 13, 2009 | 07:30 AM
Mishimoto's Avatar
Try the speaker from the passenger side on the driver's side channel. How old is the Pioneer unit? How many channels is the Alpine amp?
Edit: Also, if the headunit wires are put together with those plugs they use at circuit city instead of being soldered properly, chances are one of the pins is loose behind the head unit. I would definitely check that, especially if you are not sure how the headunit is wired.
Old May 13, 2009 | 11:50 AM
I believe the pioneer unit is relatively new not really sure though, the amp is 2 channels but ill check out how its wired to the head unit too, Thanks for the suggestions
Based_Pocket84
Jan 15, 2014 11:54 AM
zoso
Audio / Security / Video
Feb 8, 2009 07:54 PM
wangg125
Apr 22, 2008 10:22 AM
dvp95
Aug 3, 2007 05:49 PM
esoterEK..
Aug 11, 2005 07:41 PM
