Really Need Help With Speaker problem
Hello, i have been havin a little problem with my speaker for the past 6months. My drivers side speaker went out and so i took off the pannel but everything looked fine still. But ever sence only my front right speaker will work, or if i hit a big bump it will switch to just my back 2 will work and i will get a little bass from the front right one. The front left never works tho. One of my friends said it may be the x overs/crossover? But i dont know. i have no clue about audio stuff. My set up is a pioneer premier deck, eclipse speakers, and a rockford fosgate amp. Im wondering if i could just take out the amp and rewire everything like normal, would this make all the speakers work again. If so can someone tel me how i can do this... Thanks HT
I dont think the speakers are blown cuz they work, they just dont all work together... how would i know if my wires were shorted
well blown speakers can still work...to see if its your speakers when you remove the speaker cover and turn the stereo on and push the cone of the speaker in slightly and if your wires are shorted you will just have to trace the wires and look for anywhere the insulation is stripped off or wires are pinched
If there is a short circuit the amplifier would rise in a protective mode. And dynamics would be silent. At you acoustics componental or coaxial? In system crossovers from the complete set with acoustics were used?
Maybe the terminal are grounding out in the doors check the front and the rear speaker to see if the terminals are touching the door or try in the rear.
EK Domo-Kun
Audio / Security / Video
May 13, 2009 11:50 AM
