focal components
Old Jul 20, 2002 | 01:53 PM
98blkaccord's Avatar
Default focal components
me and my friend are in a heated discussion...between the polyglass 165v and the polykevlar k2 6.5 components, he thinks the polykevlar k2's are the best to put in the side door, I said it was the polyglass. My reason being is that the polykevlar is very specific with regards to imaging, while the polyglass is less discriminating with a broader range. So the polykevlar should be used in kicker panels not in the sidedoors, this should be the job of the polyglass. Who is right? any input is appreciated
Old Jul 20, 2002 | 08:18 PM
rcurley55's Avatar
New User
Default Re: focal components (98blkaccord)
I would go so far as to say that neither of you are correct....neither set are best put in a door.
All speakers must be placed correctly with the proper enclosure if you want them to image and stage correctly. The polykev's will have better tonal accuracy no matter what location you put them in, so long as they are properly installed.
But if you did a shitty/sub par job on the kev's - meaning you just threw them in the doors and wired them up, and a great job installing the 'glass set (including custom kick panels, etc) the polyglass would sound better.
Some drivers, such as MB Quart tweeters, are designed to be mounted off axis, but for the most part, any set will benefit from non-stock mounting locations.
I think tha tyou are making the mistake of associating installation quality with price tag. Every set out there will benefit from a good install.
Old Jul 23, 2002 | 09:41 PM
b18bEG's Avatar
focals are good no matter what, but the sound loose whenthey are in the door, with out a baffle. i would take the polykevlar over glass ANY day. thats waht i think, i have 165k3 in the kick and in the door and they sound great..
Grade50
Audio / Security / Video
Apr 23, 2014 05:58 PM
imadigitalgod
Sep 14, 2008 10:41 AM
DustinM
Aug 13, 2007 01:02 AM
SCIVIC94
Mar 20, 2007 10:24 PM
REVS-2-9K
Sep 1, 2004 06:49 AM
