How to modify front speaker grill
Old Mar 29, 2014 | 12:25 PM
Grade50's Avatar
10 Year Member
Default How to modify front speaker grill
If you have clearance issues with using the stock front speaker grills, is there any chance of modifying the grills to get them to fit? I'm looking through posts and while I see a lot of people cutting the stock back baskets, I dont see anyone who's cut the grills. Just wondering before I waste a bunch of time attempting and destroying my grills.
Old Apr 1, 2014 | 06:20 PM
uberEFtuner's Avatar
Default Re: How to modify front speaker grill
Just install the speakers without the stock baskets. You may need to make a set of speakers rings of 1/4" MDF to space them out so the magnet doesn't hit the glass.
Old Apr 1, 2014 | 07:12 PM
mechanix619's Avatar
Attaching the speaker to the actual door is the best install location. Having them attached to the door panel just creates rattles.
Old Apr 2, 2014 | 07:37 AM
fcm's Avatar
fcm
Old Fart
Say what????
A speaker needs to be mounted to mass, the more mass the better, a plastic door panel has very little mass compared to the door itself.
Also, you are going to get rattle no matter where speaker is mounted, but much less when speaker is mounted to mass.
Ideally you replace the stock plastic speaker housings with custom MDF housings, [that adds mass] it also allows you to get the mounting depth you need.
And yes, the grills, [inside of door panel] can be modified a bit. to give you more mounting height. 94
Old Apr 23, 2014 | 05:58 PM
Grade50's Avatar
10 Year Member
Ended up mounting the supplied spacer ring to the door panel, and the speaker to the spacer ring, then dremeled a lot of the useless plastic on the inner face of the grille. Fits and works well. Not hearing any rattles, then again, I'm just happy upgrading from the 14 year old paper stock speakers.
These were for a set of Alpine 6.5" component speakers SPS-610C
kornerk12
Audio / Security / Video
Nov 3, 2008 04:34 AM
SCIVIC94
Mar 20, 2007 10:24 PM
SheHateMe
Nov 3, 2006 07:56 AM
SPARTUS
Dec 20, 2004 03:46 AM
acuraLSSE95
Jan 1, 2002 08:00 PM
