fm reception
Old Aug 17, 2017 | 05:08 AM
cdaykin62's Avatar
Default fm reception
i have a honda crv 2012 mk3, always had a bad fm signal, i have recently fitted an after market head unit, pioneer double din unit but signal still rubbish.
any ideas?
Old Aug 18, 2017 | 05:17 AM
amerc's Avatar
Default Re: fm reception
Check wiring ... antenna disconnected or so.
Old Aug 18, 2017 | 07:26 AM
94_DC4's Avatar
Look into buying an aftermarket power antenna.
Metra makes one that you can mount on the windshield.
Old Aug 28, 2017 | 12:30 PM
Chance EG's Avatar
This isn't a bad idea.
Most of the time the antenna is routed from the head unit through the driver's A-Pillar. Attach a thick wire to the end of the antenna before you pull it through, and check if everything looks good on the antenna, and/or replace it or upgrade. Attaching that wire is critical when you start pulling it though though, or you will have one BITCH of a time fishing the wire back down the A-Pillar into the interior.
Old Aug 31, 2017 | 10:49 AM
94_DC4's Avatar
I've used this antenna with good results.
Metra Part # 44-UA200 | Aftermarket Antenna | Metra Online
Mount it on the windshield behind the rear view mirror.
Old Sep 24, 2017 | 01:15 PM
AMMOUNA's Avatar
Amplified antenna is the best solution
CrazyModGSR
May 14, 2004 10:21 PM
slowacura
Audio / Security / Video
Mar 16, 2004 10:04 PM
geminis2k
Jan 30, 2004 09:10 AM
pm41
Sep 22, 2003 11:47 PM
hydroflip
Nov 29, 2001 09:54 PM
