Fluke multimeter questions
Old Jun 12, 2004 | 07:13 AM
ScubaStevo80's Avatar
Default Fluke multimeter questions
I'm going to be buying a multimeter in the next day or two because I need it to troubleshoot a friend's motorcycle... which isn't getting power. I also figured I could use it on a car in the future...
I'm going with a Fluke... and this is the list I'm using... http://www.omnicontrols.com/fl...t.pdf
Should I get the Model 177 http://cgi.ebay.com/ws/eBayISA...=WDVW for like $50 bucks...
the 87 for around $120 http://cgi.ebay.com/ws/eBayISA...&rd=1 ...
or the 187 for $300.
Are there features I really should have or is the basic one sufficient... any help would be great. Thanks.
Old Jun 12, 2004 | 11:40 AM
EBP_SI's Avatar
Default Re: Fluke multimeter questions (VolpeOwnsU)
I would just get the 177. for trouble shooting a bike you really only need DC voltage and resistance. THe other meters are designed more for HVAC use.
I'm not sure of the price but teh Fluke 16 is a great meter. you dont have to change the leads when switching from the different scales, its auto ranging, and will measure jsut about everything but frequency. I'd check the price of that meter and if its cheap get that, otherwise the 177 will do the job
Old Jun 13, 2004 | 06:46 PM
Default Re: Fluke multimeter questions (EBP_SI)
Thanks for the reply... just for my own future knowledge, whats HVAC and what would frequency be used to measure?
Old Jun 14, 2004 | 03:10 AM
o_Rage_o's Avatar
Where did you see HVAC? The first thing that comes to mind is Heating Ventalation and A/C - I belive you would have a ammeter clamp come with the meter for these kits that can directly measure amperage by using a clothes-pin type device that basically clamps around the wire while it's on to test.
Frequency would allow you to test AC waveforms (typically 60hz for household but for different applications this can change) at the same time - you should be able to test the period (remember sine waves back in trig?? :D) - the quality/features of the meter will spec how high a frequency it can handle and read.
-Shane
Old Jun 14, 2004 | 06:55 AM
nsxxtreme's Avatar
High Voltage AC. None of the meters listed are designed exclusively for high voltage. If all you are doing is basic measurements a cheapy will work fine.
Old Jun 14, 2004 | 12:59 PM
EBP_SI's Avatar
Default Re: Fluke multimeter questions (o_Rage_o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o &raquo;</TD></TR><TR><TD CLASS="quote">Where did you see HVAC? The first thing that comes to mind is Heating Ventalation and A/C - I belive you would have a ammeter clamp come with the meter for these kits that can directly measure amperage by using a clothes-pin type device that basically clamps around the wire while it's on to test.
-Shane</TD></TR></TABLE>
he saw HVAC from my post. basically its heating ventilation and air conditioning so you'd use voltage both AC and DC, resistance. You'd also use the milivolt scale for checking the output of a thermocouple and the microamp scale for testing the output of a flame rod and similar flame safties. meters like the fluke 16 have all these built into one for convenience.
as far as frequency, its useful when working with variable frequency drive motors where you can change the motor speed by changing the AC frequency.
The clamp on ammeter is sold with the meter or separate depending on whether or not you buy the kit or if you want ones that work in different scales. ie, 0-200amps, or 200-1000amps come to mind.
as for trouble shooting the bike. get the basic one.
Old Jun 16, 2004 | 04:16 PM
o_Rage_o's Avatar
good info..
but ugh, brings to mind hours of thermocouple calibration in the labs...stupid school, i'm glad its summer!
-rage
Old Jun 16, 2004 | 07:29 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_Rage_o &raquo;</TD></TR><TR><TD CLASS="quote"> good info..
-rage</TD></TR></TABLE>
lol...i do this for a living so i have no choice but to like it. thermocouple calibration? can you breifly explain the process to me? i've never heard of something like that. all the thermocouples and thermopiles i've seen are totally sealed so the only way to really "calibrate" them is to adjust how close the flame is to the hot junction. I've done the closed and open circuit tests too.
RockAuto
Dec 20, 2018 06:26 AM
quicksilvia
Honda Motorcycles
Oct 8, 2007 02:22 AM
modulo_s
Honda Motorcycles
26
Oct 31, 2006 06:16 PM
AZNBIGPIMPN505
Feb 4, 2005 12:48 PM
Ninjaboi_on_X
Honda Motorcycles
Jan 7, 2005 10:36 AM
