Factory security system is acting up
Old Jan 5, 2006 | 01:10 AM
mudfootball's Avatar
Default Factory security system is acting up
Please help!! The factory alarm on my 02 Accord coupe has been going off recently. Sometime the system would armed when i locked the doors with the remote and other times it won't. When I pressed the lock button on my remote, the lights doesn't blink but when I pressed the unlock button the lights blink normally. The remote seems fine to me so I don't think it's the problem. The times when it does armed, the horn and lights would go off immediately without me doing anything to it. What could be causing it to do that? It goes off in the middle of the nights and my neighbors are complaining about the noise. I'd appreciated any help anyone can give me.
Also, is there a fuse for the security system that I maybe could disable and is there any where to lower the volume of the horn when it goes off??
Thank you in advance!!
Old Jan 5, 2006 | 11:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: Factory security system is acting up (mudfootball)
I believe when the oem alarms do not arm it is because there is a zone open, [hood, trunk/hatch or doors] maybe you have a faulty switch someplace.
Yes there is a fuse, should be in under dash fuse box or AUX fuse box.
To lower the volume of the horn, stuff a rag in it, or just unplug the horn at the horn. 94
Old Jan 5, 2006 | 11:09 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">To lower the volume of the horn, stuff a rag in it, or just unplug the horn at the horn. 94
Just what I was thinking... But then I started to wonder if one was so inclined, could they install a variable resistor or potentiometer inline on the positive lead to lower the volume? I'm sure that by doing so, you'd be changing the pitch and sound of the horn as well, but I'm sure it could be done...
Old Jan 5, 2006 | 11:39 AM
phaders's Avatar
Default Re: Factory security system is acting up (fcm)
All zones were closed when I armed the system so maybe the faulty switch is a possibility.
Is the fuse for the security system labeled STS? I found that on the driver's side fuse panel and don't know if it's the one.
I don't want to disconnect the horn because I would still like to have use of it. Just wanted to lower by a few decibels so it doesn't sound so horribly loud..lol
Old Jan 5, 2006 | 11:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Just what I was thinking... But then I started to wonder if one was so inclined, could they install a variable resistor or potentiometer inline on the positive lead to lower the volume? I'm sure that by doing so, you'd be changing the pitch and sound of the horn as well, but I'm sure it could be done...</TD></TR></TABLE>Yep you could, volume control for your horn, then install a real loud one and if the dork in your way didn't move on you first "toot" crank up the volume, so he thinks a semi wants him to GTFOOTW, HHHOOOOOOOONNNNNNK LOL 94
Old Jan 5, 2006 | 11:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Factory security system is acting up (phaders)
Your sure it's not SRS, I don't know what STS is?
Check the hood pin and trunk/hatch switch, [in the latch] if the interior, [dome] light is going out the doors are ok, if trunk/hatch light goes out, [when lid is shut] it's ok, you can unplug the hood pin and see if its the problem, [see if alarm will arm and not triggered.
The other possibilities are there is a short in the trigger wires, if it's the door pin- switch wires the dome light will stay on, if it's the trunk/hatch switch wire the trunk/hatch light will stay on, there is no light for the hood, so that one would be harder to check, [need a multimeter] and last but not least is the alarm itself, it may just have gone west on you. 94
beege
Acura TL, RL & ZDX
Mar 22, 2013 01:52 PM
Bolts8
Audio / Security / Video
11
Feb 15, 2013 03:46 AM
00ekcoupe
Nov 7, 2008 07:41 AM
g0tsilkk
Mar 25, 2006 08:44 AM
ctownintegra
Oct 15, 2005 11:01 AM
