Horn/lights randomly go off when doors are locked! - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Audio / Security / Video
Reload this Page >
Old 03-31-2015, 04:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Overview
Print Wikipost
Old 09-29-2011, 11:03 AM
Default Horn/lights randomly go off when doors are locked!
Hello,
I have a bit of an odd problem that I can't seem to figure out with my 2001 Honda accord EX (4 cylinder) coupe. My car has an Honda factory issued alarm system installed in it. When I lock the doors of my car (usually with my remote), the doors will lock and the alarm system makes the typical two beeping sounds when the doors lock. Over the past month or so, however, when the doors are locked and my alarm is activated, my horn will randomly start sounding off (along with headlights blinking with the horn) all on its own. It's exactly as if I would of hit the panic button on my remote,
It will happen only when the doors are locked, it will happen at random times (even when I'm vacation and my keys are hundreds of miles away with me), and lastly, the horn and lights will go off for a certain amount of time, then stop, then go off again.
Has this happened to anyone else, or would anyone have any idea what would be causing it? I can't let this keep going on, because evantually the horn and lights constantly going off will drain my battery. When I have left my far unlocked, it has not done this.
Any help would be great!
Bolts8 is offline
Old 09-29-2011, 07:03 PM
fcm
Old Fart
fcm's Avatar
Default Re: Horn/lights randomly go off when doors are locked!
When you lock the doors with the remote you arm the alarm, if the alarm triggers, [sounds like your problem] the alarm will honk the horn and flash the lights, probably for 30sec. then reset and trigger again, [again, sounds like your problem].
Most likely the problem is in the alarm itself, it could be something triggering the alarm, [doors, trunk, hood or ign. input] pretty sure your Honda alarm does not have impact or motion sensors. 94
fcm is offline
Old 09-30-2011, 05:59 AM
After talking with a mechanic I know, I was told the same thing about it being the alarm system more than likely. I was told by disarming the alarm system, it may solve the problem. I personally don't mind not having the alarm activated since I bought the car that way, but I want to be able to lock the car without worrying about by car not starting!
and the horn/lights going off in 30 second sequences sounds about right too.
Bolts8 is offline
Old 01-25-2013, 03:45 PM
I 've had the same problem twice with my 20003 Accord coupe. Last year, after a dozen or so occurrances, it went away on it's own. Today, it's back. It's exactly as you describe.
However I DO NOT have an alarm system. I think it's moisture related as it occurred during a wet period and a cold snap. may be it's a door or hood interlock?
daveydo is offline
Old 01-25-2013, 03:47 PM
I've yet to find a mechanic Honda dealer or otherwise who can diagnose it.
daveydo is offline
Old 02-01-2013, 02:46 PM
Originally Posted by Bolts8 View Post
Hello,
Check your Door Lock Actuator. There is a rubber part on the mechanism that acts like a stopper, this rubber piece presses against the mechanism telling the electronic parts that the vehicle is locked, Because this piece is broken, the part cannot make contact with the mechanism, therefore your car thinks its not locked so it unlocks and locks again. That is what sets off your alarm. This is sort of a common thing to go out on the Acura Legend and I am guessing the same is happening with your car.
I actually have to fix mine, So I will be making a write up on this soon.
Blood Riot is offline
Old 02-02-2013, 05:15 AM
Hi Blood Riot - I really look forward to your write up! I'm having the exact same problem (2003 Accord Sedan).
kozayagi is offline
Old 02-02-2013, 01:49 PM
Hi Blood Riot, It seems like a plausable cause to me. However, where I've had 2 incidences a year apart, it will be pretty hard to verify that the actuator is in fact the problem. Having said that, if the cost of the part is small then it's worth a try.
Further, as I've stated earlier, I suspect moisture to be the cause. So, I will have to inspect the rubber plunger for damage that may be allowing moisture into the actuator. I'll post what I find.
Finally Does anyone know if there is a like acuator for the hood. If so,
where is it located?
daveydo is offline
Old 02-04-2013, 05:35 AM
There should be a switch where the latch is located, the connector should be located at the bottom of the center beam of the core support.
If you want to bypass your alarm you can close the circuit on this connector and not have to worry about your alarm going off until you can figure out whats going on. This of course works for an old hunk of junk like my Legend. I'm not sure if it will be the same for your vehicle.
Old 02-11-2013, 04:09 AM
My problem got much more serious, I'm bringing the car in:
- Headlights and brakelights now flash for long periods of time silently, with no apparent rhyme or reason. Did it so much overnight a few days ago that the battery was completely dead in the AM.
- No longer gets out of gear (need to use the override every time, otherwise it acts like it's in PARK and the button won't budge).
- When I lock twice with the FOB, the horn no longer beeps once to ackowledge
- System arms sometimes, and other times it doesn't, randomly
I'll post back when I get more info from Honda this AM
kozayagi is offline
Old 02-11-2013, 06:08 AM
You might have a messed alarm system.
1feocrx is offline
Old 02-15-2013, 04:46 AM
Update: Everything's fixed! The problem had everything to do with the lower horn being corroded (10 yrs winter driving in Ottawa) and causing a short.
They replaced the horn and we did the hood latch at the same time (apparently also part of the problem). Total bill $560 /incl taxes... not much fun, but all of the problems have been solved.
kozayagi is offline
nodir
Honda Civic (2001 - 2005)
04-12-2017 08:46 PM
skhan919
06-01-2014 11:10 PM
si_motor_spt
03-26-2010 06:24 AM
7andaswitchblade
07-03-2006 07:30 PM
blackeg
08-05-2005 10:00 AM
Quick Reply: Horn/lights randomly go off when doors are locked!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
