Amp draining battery?
Old May 19, 2005 | 05:27 PM
gwsexton425's Avatar
Default Amp draining battery?
Alright, well about a month or 2 ago, my amp. cord (the fat one) was pulled out of the amp. When I was screwing it back in, the screwdriver touched the amp and it sparked a bit, I disregarded it and all seemed fine. About 2 weeks later, my battery was dead. I've been having to jump it every morning, unless I unplug it. I'm guessing there is a short in the amp? I don't know much to anything about car audio, and I don't want to pay someone to fix it. Any ideas on what is causing my battery to drain?
Old May 19, 2005 | 05:34 PM
Default Re: Amp draining battery?
Oh by the way, It's an Alpine MRP-M350 Mono (700w max power) amp. I'm not too sure if that makes a difference.
Old May 19, 2005 | 05:45 PM
o_O's Avatar
o_O
Default Re: Amp draining battery? (gwsexton425)
try checking your fuses on your amp.......also i'm assuming that your power/ground cables to your amp have crimp on connectors......any stray wires coming from those?
Old May 19, 2005 | 06:18 PM
Forgiveness's Avatar
Default Re: Amp draining battery? (o_O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_O &raquo;</TD></TR><TR><TD CLASS="quote">try checking your fuses on your amp.......also i'm assuming that your power/ground cables to your amp have crimp on connectors......any stray wires coming from those?</TD></TR></TABLE>
checking the fuses? wtf does that have to do with a battery drain?
Old May 19, 2005 | 06:19 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gwsexton425 &raquo;</TD></TR><TR><TD CLASS="quote">Alright, well about a month or 2 ago, my amp. cord (the fat one) was pulled out of the amp. When I was screwing it back in, the screwdriver touched the amp and it sparked a bit, I disregarded it and all seemed fine. About 2 weeks later, my battery was dead. I've been having to jump it every morning, unless I unplug it. I'm guessing there is a short in the amp? I don't know much to anything about car audio, and I don't want to pay someone to fix it. Any ideas on what is causing my battery to drain?</TD></TR></TABLE>Disconnect the power wire to the amp, [remove the main fuse on the power line by the batt.] and then see if its the amp thats killing the batt., and just to make sure it has nothing to do with the amp, unplug the RCAs from the amp and disconnect the trigger wire, [the thin one, on the amp, don't forget to tape it off, its live when HU is on, also don't led the RCA sig. pin touch ground.
If the batt. is still dead in the morning, I would start looking someplace else for the problem. 94
Old May 19, 2005 | 06:20 PM
Default Re: Amp draining battery? (Forgiveness)
get a multimeter and plug it into the battery once the car is off. if it's still draining, something is probably draining the battery.
unplug the amp, check the voltage again, if it's not draining anymore, then it's the amp.
otherwise, disconnect the battery and check the battery by itself, it might just be a bad battery.
Old May 19, 2005 | 08:37 PM
Loccusst's Avatar
Once you deep cycle a battery it's no good. It will never be as good as it was. Tracking down a power drain can be time consuming. When you check the curent draw from the battery with the car off there will be a little bit of curent draw...that's normal and each car is differant. You may have caused a permanent connection inside the amp on the circuit board. Normally the amp requires the remote turn on wire to know when to turn on...but who knows now. From now on when you mess around with the amp, remove the fuse up by the battery.
Old May 20, 2005 | 07:11 AM
Mr_EmO's Avatar
Default Re: (Loccusst)
happened to me before. had to get a new battery.. get a new battery and a cap
Old May 22, 2005 | 02:53 PM
strictlyimport's Avatar
Default Re: (Mr_EmO)
I have a cap for sale if you are interested. Email me at justin.barringer@navy.mil
chillerice
Audio / Security / Video
12
Feb 9, 2013 07:32 PM
nyzd79
Mar 16, 2008 12:12 PM
vargas
Nov 29, 2007 05:58 PM
carloselpavo
11
Sep 26, 2007 06:46 PM
nub_pwn
Sep 16, 2006 08:21 PM
