Alpine Amp question/help
Old Oct 1, 2004 | 11:58 PM
articbluedc5's Avatar
Default Alpine Amp question/help
I have my compontents up front and my rear 6x9's amped up on a Alpine 4 channel. Today something happend and I am getting no sound. I check every possible fuse from cd player even on the amp. I noticed the power light is flashing instead of being steady. Does any one know what could be the problem! Thanks again
Old Oct 2, 2004 | 06:23 AM
B18C_EJ8's Avatar
Sounds like the amp is in protect mode. Disconnect all of the speakers, and turn the deck off, and then on again. If the power light comes on steady, then there's a problem with one or more speakers. Speakers can blow and cause a dead short to the amp, and it makes the amp go into protect. I'd start there...
Old Oct 2, 2004 | 08:20 AM
M0NEYnH0s's Avatar
Default Re: (B18C_EJ8)
check your ground.
Old Oct 3, 2004 | 12:46 AM
Spider Man's Avatar
Default Re: (M0NEYnH0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M0NEYnH0s &raquo;</TD></TR><TR><TD CLASS="quote">check your ground.</TD></TR></TABLE>
I'm putting a nickel on bad ground.
Old Oct 3, 2004 | 12:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine Amp question/help (MilanoRedem1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedem1 &raquo;</TD></TR><TR><TD CLASS="quote">I have my compontents up front and my rear 6x9's amped up on a Alpine 4 channel. Today something happend and I am getting no sound. I check every possible fuse from cd player even on the amp. I noticed the power light is flashing instead of being steady. Does any one know what could be the problem! Thanks again</TD></TR></TABLE>What Alpine amp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the amp is in protect mode. Disconnect all of the speakers, and turn the deck off, and then on again. If the power light comes on steady, then there's a problem with one or more speakers. Speakers can blow and cause a dead short to the amp, and it makes the amp go into protect. I'd start there...
</TD></TR></TABLE>Dito that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M0NEYnH0s &raquo;</TD></TR><TR><TD CLASS="quote">check your ground.</TD></TR></TABLE> Also dito that
More then likly shorted out speaker. 94
Old Oct 7, 2004 | 07:23 PM
Default Re: Alpine Amp question/help (fcm)
I put in my other alpine and it worked. So I am taking the other one to get fixed. Maybe it got wet&gt; I don't know. I will post up to let you know Thanks guys
Old Oct 8, 2004 | 10:09 AM
I took it into the shop and the guy said he could smell that I burn out a power something. So i have to send it to alpine to be fixed.
aznd87
Nov 5, 2006 09:54 PM
lsracer27
Audio / Security / Video
Jun 14, 2006 01:42 AM
aboh6leenz
Dec 9, 2004 08:43 PM
skrewdriver88
Aug 24, 2004 08:21 PM
hugh_jazz_sponer
18
Oct 6, 2003 08:31 AM
