electrical q
Old Jan 17, 2005 | 12:57 PM
rasta420's Avatar
Default electrical q
when you need a 12V power wire for anything that you want to wire up in the car, say a vtec controller or a relay or a gauge or whatever, where should you get the 12V from? is it ok to jus splice into another wire that is supplying that 12V, or should you go directly to the positive terminal on the battery?
for example, say i spliced into the 12V wire going to a relay to power a new relay. would this affect the voltage or current going into the original relay? im trying to think of a circuit diagram, and it seems like it will be a parallel circuit where the voltage is the same...or i may be wrong.
Old Jan 17, 2005 | 03:10 PM
nsxxtreme's Avatar
Default Re: electrical q (rasta420)
Well I wouldn't splice into the cars power wires because the loads on these wire has already been determined by the manufacturer of the car. They don't design them for you to start adding things on. While it may work because they have designed in a saftey factor I wouldn't do it.
Since you plan to run a vtec controller ask yourself what happens if it dies. Or the line you attach it to dies. Something like this I would attach directly to the battery.
Old Jan 20, 2005 | 09:24 AM
PupaScoopa's Avatar
Default Re: electrical q (nsxxtreme)
Check out these pigtail fuses:
http://www.tessco.com/products...Id=12
They have a wire soldered into one leg of the fuse. I've used these over the past few years when installing auxiliary equipment and cell phones.
Old Jan 20, 2005 | 11:39 PM
rasta420's Avatar
Default Re: electrical q (PupaScoopa)
sorry if this is a dumb question, but how exactly could i use the pigtail fuses?
Gibson5469
Mar 18, 2007 05:45 PM
MugenHonda
Jul 2, 2005 11:15 AM
cleofis
Audio / Security / Video
Jun 21, 2004 08:01 PM
tyflip2
Jun 14, 2004 03:08 PM
silveraccord01
Apr 27, 2003 10:35 PM
