Electrical problem check it out
Old May 25, 2007 | 02:59 PM
1 Fly SI's Avatar
Default Electrical problem check it out
https://honda-tech.com/zeropost?cmd=fshow&id=3
Check it out please
Old May 25, 2007 | 03:39 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Electrical problem check it out (1 Fly SI)
It sounds like there something loose. I would check to see if if thats so. I would also check the main relay for being bad. Also don' look out on checking all the grounds.
Old May 25, 2007 | 04:58 PM
fcm's Avatar
fcm
Old Fart
Ditto the above.
What I want to know is, is it not getting fuel or is it not getting spark, you will need to confirm or eliminate one or the other.
It is obviously an intermittent problem and as mentioned that would indicate a poor connection, maybe corroded plug terminals, [spray contact cleaner would fix that].
There are other tests you can do to narrow down the problem.
But first thing is to check for fuel and spark. 94
airwalk07143
Engine Management and Tuning
Jun 16, 2008 11:24 AM
blackep925
Apr 12, 2008 04:59 PM
sipolt89
Dec 9, 2007 10:14 AM
TURBO
13
Jul 10, 2004 04:23 PM
