dynamat trunk install
Old Dec 15, 2002 | 04:59 PM
lodown414's Avatar
Default dynamat trunk install
do you install the dynamat in the inside of the trunk or beneath the carpet panels? i want it to look nice... but i want it to work...
Old Dec 15, 2002 | 05:36 PM
integradoc's Avatar
Default Re: dynamat trunk install (lodown414)
to do it effectivly you will have to pull all of the carpeting out of your trunk. some areas in your trunk will need it more than others. the idea behind sound deadning is to change the resonant frequency for the metal so it wont ring. thicker metal in the trunk will not need it as much as the thinner metal. the trunk lid is very important to do. if you want it to look good after you dynamat it get some 1/8 inch masonite or hardboard and cut it to fit the lid, either in one big piece or smaller pieces to fit between the supports. then just glue some carpet to them and screw them on to your bracing making sure you use short screws. the rest of the moulded carpeted pieces will fit back into place pretty easy, prvided the dynamat is not put on to thick. if your trunk has the standard charcoal grey carpet, I would recomend going to a car audio shop and get the good box carpet and spray glue.good luck
Old Dec 15, 2002 | 06:26 PM
lodown414's Avatar
Default Re: dynamat trunk install (integradoc)
thank you sir
Charlie Moua
Audio / Security / Video
Mar 23, 2010 03:43 PM
silverbullet9626
46
Jul 27, 2009 04:20 PM
TnTWRX
15
Jun 28, 2004 06:38 AM
Matgallis
Apr 10, 2003 04:18 PM
95redcivicex
Aug 24, 2002 06:54 AM
