DOOR LOCKS
Old Aug 30, 2004 | 11:05 PM
Prostart's Avatar
Default DOOR LOCKS
I recently purchased an alarm system for my car. I'm having difficulty doing it my self becuse I'm unsure of the wiring. If someone can help me the corresponding wire this would be great!
1. (-) lock output
2. (-) unlock output
3. (-) rearm output
4. (-) disarm output
5. (+) positiver door input
6. (-) Starter kill output
7. (-) Negative door input
This wiring connection would be for a 97HONDA CIVIC!
I do believe that the door wires are GREEN/ORANGE & GREEN/WHITE also light GREEN/RED are all doors. I do not understand the polarity.
PS. The alarm is a prostart CT-5000 and the installion manual can be view online at http://www.prostart.org. You will be looking at pg5 12pin accessories harness for the above information.
Thanks guys.
Old Aug 31, 2004 | 07:25 AM
fcm's Avatar
fcm
Old Fart
Default Re: DOOR LOCKS (Prostart)
I will let you know after work, I will look up your car on Direct tech, it will tell you what color and where to find and tag into. 94
Old Aug 31, 2004 | 07:44 AM
Eric R's Avatar
Oh yeah, wires suck!
Old Aug 31, 2004 | 07:33 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prostart &raquo;</TD></TR><TR><TD CLASS="quote">I recently purchased an alarm system for my car. I'm having difficulty doing it my self becuse I'm unsure of the wiring. If someone can help me the corresponding wire this would be great!
1. (-) lock output
3. (-) rearm output
Thanks guys.</TD></TR></TABLE>
1-door lock green/white green plug behind radio
2-doorunlock green/orange "
3- not used
4- not used
5- not used
6- starter kill output used to trip relay for starter interrupt black/white ign. harn.
7- neg. door trigger lt. green/red green plug behind radio
this wireing is for 97 civic HX,LX,EX the DX and CX do not have the green plug behind radio and are as follows
1,2,3,4,5,6 not used
6- starter kill same as above
7- neg door trigger green/black drivers ' A' pillar
hope this helps 94
PS the polarity is just what the wires need to "see" eg. 5 (+) door input , will trip alarm when pos. is supplied ,[ ford door pins] 7 (-) door input, will trip alarm when neg. is supplied, [Honda door pins, and almost all other cars]
Old Sep 1, 2004 | 06:20 AM
Prostart's Avatar
Default Re: DOOR LOCKS (fcm)
Fcm,
words can show my appreciation enough but THANK YOU!!!! I'll be working on it later today and by tomorrow I will let you know if this works. Again THANK YOU VERY MUCH.
Old Sep 1, 2004 | 09:03 AM
egLEGEND's Avatar
THe wire you need are going to be taped up in a green factory alarm harness. Even if the car did not come with factory keyless. On the 96 97 models, this harnes is behind the radio. Neg trigger door locks, which are the norm on all honda, except certain 04 odysey&lt;SP&gt;, work like this: There are two wire that activate the actuator (motor) of the locks. When one of the wire touches ground, and the other does not, your door will lock. If the other of the two touch ground, and the other does not, it unlocks. Its called reverse polarity.
Wires.
-Positive door out. DONT use cut and tape.
-Door trigger is in the driver kick.(WHEN DOME LIGHT IS activated by door open, alarm triggers.
-arm/re arm not ness. on Civic.
-Starter kill output goes to a relay which should be in alarm package.
--- one wire goes to ignition(black/yellow) in steering col. , the starter out put to the corresponding wire, and two other wires connect to the starter wire ( white/black) in the steer. col. One of those wires goes towards the key and the other towards the starter. YOu have to cut the (White/Black).
TIP, the parking lights are easy on this car. Get a Speaker (female) connector. On the fuse box itself, there are three open (male) connectors. Test with a test light or probe by turning the lights on and off. This will go positive when the lights are turned on.
Hope this helps.
Old Sep 3, 2004 | 08:35 AM
Prostart's Avatar
THANKS GUYS. I FINALLY GOT IT TO WORK AND WORKS LIKE A CHARM. The unit came with a hood pin switch so I tied it into the (-) door input so it acts like a fifth door. I have one thing left and that's the trunk. It has a seperate dome or interior light which comes on when the trunk is openned. It runs off the same fuse as that of the door light but is independent. Meaning when I open the door the light inside the car goes on but the one in the trunk is off. Similarily when I open the trunk the light in side the trunk comes on but the one in the car is off. Anyhow, I have the day off from work so I'll be giving it a shot. However, if anyone knows which wire triggers the trunk light and let me know this would be great.
AGAIN THANKS GUYS YOU SAVED ME DAYS AND MAYBE EVEN MONTHS OF WORKING ON THIS....LOL.
Old Sep 4, 2004 | 07:01 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prostart &raquo;</TD></TR><TR><TD CLASS="quote">THANKS GUYS. I FINALLY GOT IT TO WORK AND WORKS LIKE A CHARM. The unit came with a hood pin switch so I tied it into the (-) door input so it acts like a fifth door. I have one thing left and that's the trunk. It has a seperate dome or interior light which comes on when the trunk is openned. It runs off the same fuse as that of the door light but is independent. Meaning when I open the door the light inside the car goes on but the one in the trunk is off. Similarily when I open the trunk the light in side the trunk comes on but the one in the car is off. Anyhow, I have the day off from work so I'll be giving it a shot. However, if anyone knows which wire triggers the trunk light and let me know this would be great.
</TD></TR></TABLE>Its blue/black at dkp or fusebox also at oem alarm plug [light green] 94
Old Sep 5, 2004 | 02:51 PM
Prostart's Avatar
THANKS TO ALL OF YOU THAT HELPED ME WITH THIS PROJECT. It took some time but I saved myself a lot of money. Once you are familiar with the wiring I can't believe how easy it is and the prices people charge. My alarm now works. THANK YOU AGAIN GUYS.
PROBLEM SOLVED!!!!!!!!!!
teamworxek9
Audio / Security / Video
Mar 2, 2009 10:31 AM
canucker
Nov 9, 2008 09:24 AM
EJ8 GSR-T
11
Apr 29, 2007 03:35 PM
Just Checking In
Jun 26, 2003 04:33 PM
ketchup_gsr
Oct 29, 2002 08:05 AM
