Door Lights?
Old Jun 17, 2002 | 06:28 PM
TurBoXBirD16's Avatar
Default Door Lights?
I am trying to hook up an alarm
and i know it should connect the door lights so that it knows when i opened the door or not
but i am not sure which wires i need to hook up for it..
is there two wires that i need to connect to the lights? or just one??
thankd IA
Old Jun 17, 2002 | 06:50 PM
t's Avatar
t
Default Re: Door Lights? (xbird)
It should only be one wire. Depending on what alarm you have the trigger wire would want to see a positive trigger or a negative trigger. If negative trigger just grab the passenger door trigger wire and it will get all the doors.
Old Jun 17, 2002 | 06:51 PM
Default Re: Door Lights? (t)
what if it's positive??
and is that possible that it wants both positive and negative?
Old Jun 17, 2002 | 06:59 PM
t's Avatar
t
If positive you may need a relay, again, depends on the alarm(some will accept pos on one wire and neg on another wire)
All it needs is one wire to sense the door is open. (So it is highly unlikely it will need both)
If it is a honda, the doors are a negative trigger
[Modified by t, 8:00 PM 6/17/2002]
Old Jun 17, 2002 | 07:06 PM
t's Avatar
t
Default Re: Door Lights? (EVIL Teken)
You are correct and I am thinking older than that. (Actually I dont ever think I came across a pos triggered honda)
What I meant for the original poster is that some alarms want to see a postive trigger.
[Modified by t, 8:08 PM 6/17/2002]
Old Jun 17, 2002 | 07:08 PM
louder160's Avatar
what year and make is it. I can send you some info that might help.
Old Jun 17, 2002 | 07:09 PM
Default Re: Door Lights? (louder160)
93 civic ex
Old Jun 17, 2002 | 08:10 PM
louder160's Avatar
I just emailed a tech sheet on your car.
Old Jun 17, 2002 | 08:12 PM
thanks very much
Old Jun 19, 2002 | 10:21 PM
philly-O's Avatar
if all else fails you can pull out your door pin and follow that wire to a more accesabe spot such as door jam and catch it there
kcjohnnyboy
Audio / Security / Video
27
May 10, 2008 08:30 AM
low_crx87
Oct 8, 2005 12:58 PM
Odessa
19
Aug 3, 2004 06:37 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
willyboyK20
Apr 18, 2002 04:51 AM
