Dome Light Wiring help-
Hey guys question...
I have an aftermarket cd player installed in my car. My car was broken into a few months back and thankfully nothing was taken. But they definently tried. They broke my console trim trying to get at my unit... I replaced it all a week ago and noticed that my stock radio was buried in the dash. Upon removing it i realized that the dome light is powered by a wire going into the radio. Someone on jdmu confirmed this for me, my question is
does anyone know what wires i could cut and connect to bypass having the radio?
the car is a 97 ex, the dome light works but the light wont come on when i open the doors.
thanks guys
thanks guys
as long as you do not have oem key-less entry all you need is this... http://www.scosche.com/scosche...HA03B can be found at most car audio shops, you can also get this... http://www.scosche.com/scosche...HAK3B
If you have oem key-less entry/alarm, you will have to leave the oem HU wired behind the dash, the [R/F section is in the radio and the dome light "supervision"] or install an aftermarket alarm and wire the door locks.
94
94
to connect the wires...look for a green harness
the wires are light green with red trace and light green with black trace.
connect these wires together and your dome will work with the doors.
Mikes2000civicsi
Nov 11, 2007 08:20 AM
