Distribution block question
Old Dec 4, 2012 | 12:50 PM
unspankable's Avatar
Default Distribution block question
Hi so I'm an electrical noob and need a little help understanding distribution blocks.
I'm going to relocate my battery to the trunk and run a 0 guage power cable to the distribution block mounted on the firewall. My question is this- Say the block has two 0 gauge inputs and a bunch of 4 gauge outputs and i want to run 0 gauge all the way to my starter can i run 0 gauge out of the second distribution block input to the starter and use the 4 gauge outputs for the rest of my accessories/fuse box? Will the second "input" allow power to reach the starter?
I don't really understand the difference between an input port and an output port. Is the output port fused and the input not?
Old Dec 4, 2012 | 01:36 PM
Fliptard's Avatar
Default Re: Distribution block question
and why are you using 0 gauge wire? seems a little big.
Old Dec 4, 2012 | 01:40 PM
It was just used as an example it could be any gauge. Are both the inputs on the block connected i.e just a series circuit?
Old Dec 5, 2012 | 06:43 PM
Aau's Avatar
Aau
basically a distribution block is just a big peice of metal that spreads the connections out so u can hook the power wire to that to get power instead of going straight to the battery with lots of multiple wires, if u look at where the original battery wire was, trace it down and most likely it's split to the starter and/or the fuse box, and from the fuse box it splits all the other electrical components
88efZ6
Audio / Security / Video
Nov 7, 2008 08:09 PM
em2ssm02
Aug 31, 2007 06:25 PM
thejacka
18
May 26, 2006 07:15 PM
Muckman
19
Dec 29, 2005 10:59 AM
grnsol
Mar 1, 2002 07:17 PM
