Diode testing
Old Aug 25, 2004 | 10:37 AM
Odessa's Avatar
Default Diode testing
How can I test to see if a diode is dead or alive?
Old Aug 25, 2004 | 10:52 AM
nsxxtreme's Avatar
Default Re: Diode testing (Odessa)
use a multimeter set it on the diode setting. Put the red lead on the diode side with the bar the negative lead on the other side it shout say around .7
If your multimeter does not have this feature use the impedence setting. measure in both directions one of the ways should have a significantly lower resistance.
Either of these test does not garantee the diode is good. What are you using it for?
Old Aug 25, 2004 | 11:14 AM
Odessa's Avatar
Default Re: Diode testing (nsxxtreme)
I'm using it to isolate sensors, door locks/unlocks, door triggers and probably a few other things to install my alarm. I will try what you said tonight.
type Gendy
Jul 15, 2014 02:57 PM
importdude2000
Audio / Security / Video
12
Jun 20, 2011 06:54 PM
iLL_Rex
Aug 19, 2008 05:18 PM
EJ8 GSR-T
11
Apr 29, 2007 03:35 PM
yoda888
Jan 8, 2004 10:27 AM
