deck problem
Old Jun 17, 2007 | 07:26 PM
matmcg's Avatar
Default deck problem
okay well i had a kenwood deck in my car when i bought it that was 45 x4 and i had a 52 x4 sony one i wanted to swap in. well anyways i cut the wires to the ken wood and hooked them up to the sony. the sony wouldnt turn on so i put the wires back together to the kenwood and the kenwood wouldnt turn on either so currently i have no sound PLEASE HELP
Old Jun 17, 2007 | 08:04 PM
94_DC4's Avatar
Default Re: deck problem (matmcg)
Have you tested the radio fuse in the fuse box under the dash and/or under the hood? BTW what kind of car do you have?
Old Jun 19, 2007 | 09:19 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">okay well i had a kenwood deck in my car when i bought it that was 45 x4 and i had a 52 x4 sony one i wanted to swap in. well anyways i cut the wires to the ken wood and hooked them up to the sony. the sony wouldnt turn on so i put the wires back together to the kenwood and the kenwood wouldnt turn on either so currently i have no sound PLEASE HELP</TD></TR></TABLE>
there really should be no reason to cut the wires if you have an interface harness...do you have one??? a little more info would be appreciated.
ok...by what u r telling us is that you cut all the wires together right...???
by doing so you probably popped a fuse. hook up the wires as you normally would then check/replace your fuses. me personally...would keep the kenwood and smash the sony to bitz...then set the remains on fire.
Old Jun 19, 2007 | 01:12 PM
matmcg's Avatar
okay ill reword everything
i realized i had a deck with higher output
the wires had been cut out of my other car so there was no harness
all the wires were in a harness on the integra so i cut them and spliced them together to the new deck
turned on the battery and it didnt work
so i put the old deck back on and spliced the wires exactly to the wires that had been cut
turned the battery on didnt work
there was a fuse on the sony , wasnt blown , there was a fuse on the wire of the kenwood , wasnt blown
the car is 1995 integra
Old Jun 19, 2007 | 01:13 PM
matmcg's Avatar
i may try later with another deck i have which is insignia
Old Jun 19, 2007 | 01:47 PM
B18C_EJ8's Avatar
Default Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">okay ill reword everything
the car is 1995 integra</TD></TR></TABLE>
First of all, power output is irrelevant in this situation.
Second, it's obvious that you either have something wired incorrectly or you have blown a fuse (or more than one).
Your next step is to stop trying new decks and test the red and yellow wires from the decks to power. You should have constant 12v on the yellow and 12v on the red only when the key is on (in the ACC or Run position).
Get a meter or test light and verify those wires. If you're not getting power, check the fuses. There's a radio fuse under the hood and one under the dash.
And by "check", I mean verified for continuity with a meter, not just by "looking" at them.
Old Jun 19, 2007 | 02:20 PM
matmcg's Avatar
ive done the testing and yes i do get power constant and ignition
the deck is connected now exactly as it originally was so all i can think of is that a fuse blew somewhere else so where should i check
Old Jun 19, 2007 | 02:49 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Is the unit well grounded? any pics?
Old Jun 19, 2007 | 03:01 PM
matmcg's Avatar
sorry no pics but the unit worked perfectly fine until i cut the wires
Old Jun 19, 2007 | 03:03 PM
did you cut the wires all at one time? Something is not getting power or ground.
Old Jun 19, 2007 | 03:06 PM
matmcg's Avatar
yaeh i cut them all at once right from the harness
Old Jun 19, 2007 | 03:14 PM
There is your problem. There is a blown fuse some were. I not sure how you are getting a reading for 12 volts on the battery or acc wire. Check all the fuses in the driver dash and under the hood. You never cut across a row a wires at the same time. Its one by one if you have to. Or make sure the battery is disconnected if you do. Even thou I still don't reccommend it.
Old Jun 19, 2007 | 03:17 PM
matmcg's Avatar
okay i will go check fuses and get back to u
Old Jun 19, 2007 | 03:25 PM
Old Jun 19, 2007 | 04:13 PM
matmcg's Avatar
okay well i just checked ACG fuse and RADIO fuse and well they are perfect
I noticed somethign else in the integra there is a clock that sits in the dash
the clock stopped working when the deck was removed there is no longer any light
Old Jun 19, 2007 | 04:21 PM
94_DC4's Avatar
If the clock no longer works more than likely the 7.5A fuse in the fuse box that is in the engine compartment is blown.
Old Jun 19, 2007 | 04:22 PM
What about the fuse under the hood? There is a radio one there too.
Old Jun 19, 2007 | 04:25 PM
matmcg's Avatar
where is it located and wahts the name of it sorry i may sound like an idiot but i really dont know where that one is under the hood
Old Jun 19, 2007 | 04:38 PM
Default Re: (94_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">If the clock no longer works more than likely the 7.5A fuse in the fuse box that is in the engine compartment is blown.</TD></TR></TABLE>
There is a fuse box under the hood. check there to make sure the fuses are good. Pull each one out to look. don't just glance at them. bad ones can look good.
Old Jun 19, 2007 | 06:05 PM
matmcg's Avatar
thank you guys so much it was the 7.5a just like he said i connected it and it worked except the sony deck is kind of ****** up sometimes the dial doesnt work and sometimews buttons dont work so i think i will switch back to kenwood after recheckin the wires one time
Old Jun 19, 2007 | 06:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">ive done the testing and yes i do get power constant and ignition
the deck is connected now exactly as it originally was so all i can think of is that a fuse blew somewhere else so where should i check</TD></TR></TABLE>
If the fuse was blown the battery wire would not work....... were you lying to us on testing them
Old Jun 19, 2007 | 06:44 PM
94_DC4's Avatar
Default Re: (wrx-killer-Sti eater)
Liar, liar pants on fire!
Old Jun 20, 2007 | 04:52 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">yaeh i cut them all at once right from the harness</TD></TR></TABLE>
like i said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">ok...by what u r telling us is that you cut all the wires together right...??? by doing so you probably popped a fuse. hook up the wires as you normally would then check/replace your fuses. me personally...would keep the kenwood and smash the sony to bitz...then set the remains on fire.
i think the problem here is that you used your theif skills when you should be using install skills give the radio back to the person you stole it from.
Old Jun 21, 2007 | 12:58 AM
I don't think he stole it is his own fuse is blown
Old Jun 21, 2007 | 05:33 AM
jz98ctr's Avatar
he still could've cut them one at a time
most humans are creatures of habit...
hust1er
Audio / Security / Video
Jul 2, 2007 06:03 AM
H.
Aug 22, 2006 08:56 AM
byronl
Jun 22, 2005 08:16 AM
Tokyo_X-treme_Racer
Mar 3, 2005 03:45 PM
RSVTECDC4
Mar 15, 2004 10:08 PM
