In-Dash Video for del Sol
Old Nov 21, 2006 | 09:02 PM
Flatland2D's Avatar
Default In-Dash Video for del Sol
Just wondering if anyone out there has installed or come across a del Sol with an in-dash DVD player. I'd really like to add video to my car but the current HU placement isn't ideal for this.
1) The shift **** is really close to not allowing the screen enough room to slide out (I'm guessing you'd have to at least be in 2nd/4th/reverse for it to work).
2) The HU sits back in the console to make room for the slide up cover. Since it's not flush with the console, I would think the screen would never be able to go vertical and anyways angle down.
I guess maybe the only good way to do it is by making a custom dash. I'm just hoping that there's a kit out there or something that'll simplify it. If anyone has had success with a motorized flip up display in a del Sol I'd like to here how it works.
Thanks for the help!
Old Nov 22, 2006 | 04:37 AM
skingfreak's Avatar
Default Re: In-Dash Video for del Sol (Flatland2D)
post a pic of your dash, we might be able to come up with idea for ya, whether it be custom, or an "oem" fit
Old Nov 22, 2006 | 06:24 AM
fcm's Avatar
fcm
Old Fart
Just find a flip-out that has adjustable/extendable "slide", there are a few out there.
The shifter will be an issue, but as you say placing it in 2nd, 4th or rev, would solve that problem. 94
Old Nov 22, 2006 | 02:50 PM
teler86's Avatar
Default Re: In-Dash Video for del Sol (fcm)
what about something like this
http://www.circuitcity.com/ssm...il.do
Old Nov 22, 2006 | 02:55 PM
Itzmy91Teg's Avatar
kenwood's kvt-617dvd i think it is, has an extendable face that slides out more than just the screen...lemme c if i can find a pic...mite still have probs wit the shifter tho.....i know the screen extends up to 5 or 6 inches out from the player...
http://www.crutchfield.com/S-h...L#Tab
Old Nov 22, 2006 | 03:29 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i know the screen extends up to 5 or 6 inches out from the player...</TD></TR></TABLE>
And just how in the hell is that going to help when a regular deck is an inch or less from the shifter to begin with???
Old Nov 22, 2006 | 03:31 PM
Itzmy91Teg's Avatar
Default Re: (Itzmy91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itzmy91Teg &raquo;</TD></TR><TR><TD CLASS="quote">i know the screen extends UP TO 5 or 6 inches out from the player...
http://www.crutchfield.com/S-h...L#Tab</TD></TR></TABLE>
Old Nov 22, 2006 | 03:38 PM
B18C_EJ8's Avatar
You're a retard... A screen that can extend at all is of no use to anyone with a Del Sol... Please refer to the OP's concern #1. Here. I'll help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1) The shift **** is really close to not allowing the screen enough room to slide out (I'm guessing you'd have to at least be in 2nd/4th/reverse for it to work).</TD></TR></TABLE>
Old Nov 22, 2006 | 03:46 PM
Itzmy91Teg's Avatar
Default Re: (B18C_EJ8)
read it wrong. thought he was askin if anyone knew of a screen that slides out then up. yes i know there's going to be problems with the screen because of the shifter.
Old Nov 22, 2006 | 04:02 PM
blkacgsr's Avatar
my friend had a clarion screen in his del sol and he had a short shifter and it worked fine. i can't remember if he had the radio cover or not.
Old Nov 24, 2006 | 04:24 PM
Flatland2D's Avatar
I just installed a KD-AVX2 in my wife's car (the one that teler86 mentioned). It's really nice but I want one with a 7" screen. Don't need any navigation, but having it as an upgrade would be nice.
Although the shift **** is still a concern, I'm pretty sure it wouldn't matter as long as it's pulled back. I'll look into the ones with adjustable slide. That Kenwood one looks real nice.
Old Nov 25, 2006 | 06:40 AM
jdmturbosol's Avatar
Default Re: (Flatland2D)
just about any flip out screen will work in a del sol
stock shifter must not be in 1st, 3rd, or 5th gear when motoring out or in
angle is always a concern in the sun, but with my clarion the radio cover works perfectly and i can angle it back about 3 degrees and glare was eliminated
I also have a seperate dvd unit under my glovebox in a custom enclosure
ohh yeah
you cant adjust your climate control with the screen flipped out
hope this helps
Old Nov 27, 2006 | 11:25 AM
blkacgsr's Avatar
Default Re: (jdmturbosol)
you can't adjust in my integra either. i just angle it forward and slide my hand behind it and adjust the climate.
Old Nov 30, 2006 | 03:52 PM
8520's Avatar
Default Re: (blkacgsr)
Kenwood's work well
Old Dec 1, 2006 | 04:24 PM
cockerkid008's Avatar
Default Re: (misanthropist)
id be afraid to hit my knuckles on that screen
Old Dec 1, 2006 | 04:42 PM
8520's Avatar
Default Re: (cockerkid008)
I never did. Shifter's in neutral in that pic
Old Dec 1, 2006 | 10:09 PM
Jose-aka-Pedro's Avatar
^^ Is that your clock, In the air vents. 1:26
Modified by Jose-aka-Pedro at 1:44 AM 12/2/2006
Old Dec 2, 2006 | 12:34 AM
8520's Avatar
Default Re: (Jose-aka-Pedro)
Volt meter
OmgDelSol
Audio / Security / Video
Jun 9, 2013 03:41 PM
Knac2118
May 16, 2011 07:45 PM
ek7shane
May 27, 2008 07:54 AM
93EH6
Feb 17, 2004 10:26 PM
ckdelsol
Nov 11, 2001 07:28 PM
