In dash TV in 2000 Integra?
Old 01-30-2008, 01:35 PM
Pr-Type-R's Avatar
Default In dash TV in 2000 Integra?
well i have a 2000 ITR and i have an indash TV i got off my friend who parted his car and it works really good and i like it. but the problem is when i open the 7 inch screen it comes out and hits the dash board ive adjusted it so that it stops but the angle is quit anoying and i can barely see the screen. is there any modification i can make so the unit sticks out a little more from in the dash and can be more pleasurable to view? or am i better off getting another unit?
Old 01-30-2008, 04:39 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: In dash TV in 2000 Integra? (Pr-Type-R)
make ad model of the radio.
Old 01-31-2008, 04:25 AM
fcm
Old Fart
fcm's Avatar
Your best bet is a double din unit, although if you have not tried already, mount the flip out at the bottom of the opening and see if that will get you the angle you need. 94
Old 01-31-2008, 06:25 AM
i my honda
Global Mod
White Smoke's Avatar
I'm guessing you have the unit mounted by way of screws into the side of it. Try getting a dash kit and using the sleeve/collar setup but mount the collar further out from the center console so the radio will stick out another 1/2" or so. It may not look as nice but it should get you where you wanna be.
Old 01-31-2008, 09:28 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: In dash TV in 2000 Integra? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing you have the unit mounted by way of screws into the side of it. Try getting a dash kit and using the sleeve/collar setup but mount the collar further out from the center console so the radio will stick out another 1/2" or so. It may not look as nice but it should get you where you wanna be.</TD></TR></TABLE>
Regardless, the screen will probably contact the shifter. A double-din is your best bet.
Old 01-31-2008, 01:09 PM
Pr-Type-R's Avatar
Default Re: In dash TV in 2000 Integra? (JDM_Ej)
the model is an Jensen VM9511TS. and the person i bought the car off of had an indash TV unit in it and he mounted the dash kit where the pocket is on the top. it comes out good its jsut the angle is quite annoying to look at and i got my unit for only 80 bucks off a good friend of mine and works beatifully. could u explain the way to get it to stick out more in depth? thanx in advance
Old 02-01-2008, 05:51 AM
Ricky616's Avatar
just buy a mounting kit and mount the radio cage onto the kit , then make sure it sticks out a little bit more so you can have enough space so it doesnt rub.
Old 02-04-2008, 11:26 PM
DISROK1's Avatar
sell it before it brakes and get a double din.
kleangsr
Audio / Security / Video
09-26-2005 12:04 PM
Setsuna F Seiei
09-16-2004 12:49 PM
greenbirds
06-25-2004 12:34 PM
Quick Reply: In dash TV in 2000 Integra?
