Damn Magnet!
Old Dec 12, 2002 | 03:48 PM
Turbo Powa's Avatar
Default Damn Magnet!
I just got some 300 watt 6 1/2 for my civic. I tried cutting plastic and I still can't fit it. I guess I need to cut more. I wanted to know if it will interfeer with the window.from the rim of the speaker to the magnet is about 2 and a half inches. I only cut a piece of the pastic which is the half moon shape piece. There is more that I need to cut but wanted to make sure that 2 and a half inches is good enough not to hit the window when it goes all the way down. This is going into a sedan 98 civic.
Old Dec 12, 2002 | 04:23 PM
Turbo Powa's Avatar
Default Re: Damn Magnet! (Panda EK)
anyone????????
Old Dec 12, 2002 | 05:09 PM
b18bvtec4drteg's Avatar
well I had the same problem with some MB Quart on my teg. You need spacers to make them fit. I dint want to go thru the trouble and just replaced them with Alpine6.5 with smaller magnets.
Old Dec 12, 2002 | 05:38 PM
TurboBumblBee's Avatar
your speakers might fit if you cut the rest of the stock spacer away.. cant tell forsure.. your probably gonna end up needing to make spacers for them..
Old Dec 12, 2002 | 05:52 PM
Turbo Powa's Avatar
Default Re: Damn Magnet! (95CivicEX)
when you guys say spacers what do you mean?
Old Dec 12, 2002 | 06:06 PM
RaceTilIDie's Avatar
you can also space out the window track.
Old Dec 12, 2002 | 06:08 PM
t0p_sh0tta's Avatar
A wooden ring/ kinda like a donut. You stick it in between the speaker and door, or the stock piece, so that it clears the window.
Old Dec 12, 2002 | 06:15 PM
Turbo Powa's Avatar
Default Re: Damn Magnet! (REVOEVOM)
but how do I test it to see if it will clear it? Roll the window down after I install it?
Old Dec 12, 2002 | 07:47 PM
Slowly
Old Dec 12, 2002 | 08:15 PM
dannyboi's Avatar
You should have the window down place the speaker in and make sure it fits tightly. If the magnet hits you need to space it a little more.
Old Dec 13, 2002 | 01:58 PM
JDubya's Avatar
when i put Infinity 2-ways in my teg, i had to cut out basically the whole backing of that black plastic piece. Then they fit right in there w/no probs.
Old Dec 13, 2002 | 02:01 PM
nsxxtreme's Avatar
Default Re: Damn Magnet! (Hybrid Teg98)
You can buy premade plastic spacers with different thicknesses from your local stereo shop.
Rmanzano
Audio / Security / Video
Nov 6, 2011 09:27 AM
Redgts
Honda S2000
14
Oct 9, 2009 02:11 PM
ph0shizzle
13
Aug 1, 2006 11:32 AM
bleebdat
May 20, 2004 10:13 AM
CaMiKaZi
May 12, 2003 08:43 AM
