cut off switch
Old Oct 18, 2004 | 06:03 PM
DsBananas94LS's Avatar
Default cut off switch
I have an alarms w/ a cut off switch and all that stuff but i stiff feel like vulnerable I wanna know if you guys can help me on more tips on how to keep me car from getting stolen my alarm is upgradeable i plan to put a two way pager ang get some more cut offs give some ideas please thanks
Old Oct 18, 2004 | 06:42 PM
JRciv's Avatar
Default Re: cut off switch (DsBananas94LS)
I've been thinking about wiring a switch into the fuel pump wiring and hiding a toggle switch under my seat or something. That would be really simple to do.
Old Oct 18, 2004 | 08:46 PM
EK k kay's Avatar
Default Re: cut off switch (JRciv)
Nothing will keep your car from getting stolen. The best thing to do is keep it in the garage, but then again when you're out there's no garage for you to park in. Use 6 autolocks, two for the clutch, 2 for the brake, and two for the throttle. Weld your steering column shut with a lock and key to open it. Put your car in first gear and put some rocks by the bottom of the shifter so they cant put it in neutral and tow it. Custom make a quick release handle for your e-brake and take it off so they cant tow it since they cant disengage it. Remove all your wheels and put 16 or 20 for 5-lug different wheel locks on the studs so they cant put steelies on it and roll away. Or you can get air suspension and slam it to the ground. Unplug everything in your engine bay. Relocate or remove your battery at night. Put a steel mesh fence type thing over your engine bay and lock it up. That should keep them security guessing for a while.
Ok now seriously, just get hood locks, wheel locks, clubs, autolocks, and a couple kill switches for your fuel or something else. Also try to keep your car garaged or blocked in so they cant tow it unless they drag it through 2 cars. Have alarms on those cars too.
Old Oct 18, 2004 | 09:36 PM
JRciv's Avatar
Default Re: cut off switch (chowmien)
Anyone see Taxi?
What I need is the hydraulic lift system built into the cab. Then I could just raise my car off the ground when I park.
NovaRex
Mar 19, 2015 09:24 AM
hOndafienD 04
Apr 28, 2004 08:35 PM
MileHigh
Audio / Security / Video
Sep 27, 2003 06:13 PM
incognitoracerr
Jan 10, 2003 07:03 PM
sirminder
16
Jun 5, 2002 11:15 PM
