Custom Enclosure?
Old Aug 9, 2004 | 11:03 AM
cvclover's Avatar
Default Custom Enclosure?
I finally heard some 12 inch Type R's, and I decided I want two.
I also want to install them in the left and right "pockets" that you see near the trunk door.
If anyone doesnt understand what I'm talking about, I mean where the left and right part of the trunk near the rear wheel wells dip out. I want to do this to save space, as a regular sub box would be way too big for me.
Will this even be possible? Will it hurt sound?
Old Aug 9, 2004 | 11:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: Custom Enclosure? (cvclover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvclover &raquo;</TD></TR><TR><TD CLASS="quote">I finally heard some 12 inch Type R's, and I decided I want two.
Will this even be possible? Will it hurt sound? </TD></TR></TABLE>Can you say Fiberglass, as long as the air volume is right for the sub, and the box is airtight you are good to go, that said, subs sound the best,[in mono] in one box, next to each other. 94
Old Aug 9, 2004 | 07:32 PM
cvclover's Avatar
Default Re: Custom Enclosure? (fcm)
Why does the box have to be airtight?
How do I know if the air volume is enough? What if it isnt? It blows?
Old Aug 9, 2004 | 08:05 PM
Qckrun's Avatar
The box has to be airtight, to make the subwoofer sound better. With a non airtight box, your going to have leaks, thus making it sound like crap.
Air volume..... the subwoofer should come with a manual that says the ideal box size. Im predicting the Alpines are probably about a 1-2cubic foot, maybe make a litle fiberglass box that huges the side of the car. If u get to much air space, it could possible blow. If your doing a sealed box..... just do L x W x H /1728.
Old Aug 10, 2004 | 02:36 AM
NCRXSi's Avatar
Check out this site, its one of the better step by step DIY sites I've found.
http://web.njit.edu/~cas1383/proj/main/
Old Aug 10, 2004 | 08:02 AM
cvclover's Avatar
Default Re: Custom Enclosure? (NCRXSi)
If the 2 subs are facing eachother on either side of the trunk, are there any problems?
Old Aug 10, 2004 | 11:45 AM
debogsr's Avatar
Good luck finding some type R's. Theres not to many left since there discontinued. You should probably research alot more about box's and different types of enclosures to learn more. Me and Crazygsr101 just build a mdf sealed box for one alpine type r 12, and it sounds great. The box is very small also. IF u want i can post up some pics later.
Old Aug 10, 2004 | 07:03 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvclover &raquo;</TD></TR><TR><TD CLASS="quote">If the 2 subs are facing eachother on either side of the trunk, are there any problems?</TD></TR></TABLE>Yes you can get cancelling of bass. 94
Old Aug 10, 2004 | 07:22 PM
cvclover's Avatar
But my subs are going to be a bit angled, so they are directly not facing eachother.
I heard from others that there wouldnt be a problem
Old Aug 11, 2004 | 07:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvclover &raquo;</TD></TR><TR><TD CLASS="quote">But my subs are going to be a bit angled, so they are directly not facing eachother.
I heard from others that there wouldnt be a problem</TD></TR></TABLE> That works, and if you want to get the angle just right, mount them onto two MDF panles place them apart from each other the same distance they will be in the car send a tone into them and with a dB meter placed in front of them ,[ the same distance away as the speakers are from each other] adjust the angle of speakers till you get the highest spl,[ it will be a small differance] then use that angle in the boxs.
For the others that say its not a problem, a few days ago I had a guy come into my shop in an old prelude wanting to know how to get more bass, he said he had two 10" type Rs and 500watts of power, Im thinking that should work, there must be something wrong,so we go and have a look at his setup , two small hatchback boxs in back corners of trunk faceing each other moved them to face up and back behind seat, bingo, got bass? try it , face two subs towards each other a few feet apart ,even out of a car, listen, then angle then away from each other even a little, then tell me its not a problem, trust me I have been installing car audio for 30+ years. 94
solar2005
Oct 9, 2009 05:14 AM
M1K3
Audio / Security / Video
Dec 11, 2006 01:53 PM
EF_ST@TUS
Aug 8, 2005 08:32 AM
My Db2 AinT JDM
Mar 29, 2005 01:01 PM
92BlackSi
Dec 3, 2003 06:50 PM
