crx sub cut out
Old Oct 8, 2004 | 08:26 PM
crx90rcr's Avatar
Default crx sub cut out
ok u sit in a car and turn it on and then drive decide you would like to put ur subs on they dont work but then when go to fix it they work so what i have found is that if the car is on my subs cut out car is off they will work my set up is pionier head unit
going thruogh new wires and rca jacks to
a rock fosgate punch 45 amp old school
and 2 8 inch subs and 2 horn tweeters
new thick *** ground wire 6 inches
every thing is hooked up fine but i noticed on my old head unit there is a voltage regulator oops didnt instal that could that b a problem or is that olny needed in lasers
so does any one kno y my stereo cuts out
Old Oct 9, 2004 | 08:16 AM
crux131's Avatar
Default Re: crx sub cut out (crx90rcr)
Odd, everything works when the car is not running, but quits when you crank the car??
What size power and ground cable are you running?
Are you sure that the turn on lead is hooked to the propper wire from the head unit?
Where is it grounded?
Maybe it is a bad ground location, and the viration or something about the car itself is interupting the ground to that location????
Maybe it is a voltage issue, and the amp isn't getting enough current when the other accesories in the car are on??
Weird, the older Punch stuff was awesome, and if it will work with the car off, I would assume the amp was OK??
good luck, maybe checking some of these things can help you.
Old Oct 11, 2004 | 03:18 PM
crx90rcr's Avatar
Default Re: crx sub cut out (crux131)
yea it all work when its off
the wires i am using are def big enough my dad had the stareo b 4 me and he used smaller stuff but i tried it and it cut in and out how it is now so i tried changeing it
which wire should b the turn on lead my dad is like a pro installer he did his 3 times then once in my moms van he did 2 of his brothers stareos and all these other ones 4 his freinds
i did the ground it was on a pole from the spair tire but i changed it to like 10 inches from the amp on the floor type dealy
my dad just noticed there is no volt regulator i wounder if i put that in would it help
yea i love how it sounds when my car isnt running but its so weird like it works when the car first turns on but then after like a couple mins of driveing it turns off and the whole amp turns off like even the on light
Old Oct 12, 2004 | 05:07 PM
crx90rcr's Avatar
2 hard 4 all u huh
Old Oct 12, 2004 | 06:11 PM
underage's Avatar
probably have a loose connection and when the car runs it shakes it enough to make it cut out.
Old Oct 12, 2004 | 10:23 PM
archmage's Avatar
Check fuses, grounds, any hard-wired connections...
That's all I can suggest ATM.
Old Oct 13, 2004 | 10:59 AM
LSP's Avatar
LSP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx90rcr &raquo;</TD></TR><TR><TD CLASS="quote">2 hard 4 all u huh </TD></TR></TABLE>
actually i have a harder time trying to understand your typing lol. Take it to a stereo shop and have them go over the wiring.
AndrewM90
Audio / Security / Video
Sep 12, 2012 08:26 PM
eggie75
Dec 13, 2011 05:31 PM
chi_gsr
Aug 12, 2010 04:25 AM
mayfly
18
Jul 27, 2009 11:06 AM
osuPrelude
Jan 20, 2003 07:27 PM
