Crossover frequency for sub
Old Apr 25, 2003 | 08:39 AM
Xsi's Avatar
Xsi
Default Crossover frequency for sub
Hey guys, i'm trying to set the crossover on my Alpine MRV 1005 running an Ultimate Sound Cupric 12 inch sub.
The sub has frequency response 23Hz - 400Hz
Fs 23.2Hz (whatever that is)
Sensitivity 89dB
What do you think would be a good level to set the crossover at? I know a bit about wiring them up but have no idea about frequencies.
The amp has a parametric equalizer, I'm trying to work out what it does and how I should use it, from the looks of things it makes a certain frequency louder, depending on what you choose. Anyone have an Idea of what this should be set at?
I have a copy of the section in the amps manual:
Also, if the amp is running 2 channel to a DVC sub should the switch be at mono or 1+2 ?
Old Apr 26, 2003 | 04:30 AM
Xsi's Avatar
Xsi
Up
Old Apr 26, 2003 | 05:28 AM
t0p_sh0tta's Avatar
Default Re: (Xsi)
Start with 80hz and work your way down.
I can't help with the parametric, but play with it until it sounds good.
Old Apr 26, 2003 | 11:03 AM
vteg's Avatar
New User
Default Re: (Xsi)
Looks like you should use 1+2.
Low pass at 80 is a good starting point for most systems.
Old Apr 26, 2003 | 07:18 PM
Xsi's Avatar
Xsi
Default Re: (vteg)
Thanks guys
I'll have a fiddle with it.
.spicoli
Audio / Security / Video
15
Sep 24, 2005 02:11 AM
jordan-boxer
Apr 8, 2004 07:34 PM
dxhatch93
Mar 19, 2003 12:17 PM
Nader_D
Feb 7, 2003 11:48 AM
all420
Dec 13, 2002 04:31 PM
