Blown subwoofer?
Old Mar 18, 2003 | 07:19 PM
dxhatch93's Avatar
Default Blown subwoofer?
I have a jl w0 12 connected to a pheonix gold qx 2180 amp and lately it kinda seems like it doesnt hit as hard as before on a low setting. Ive had it for a couple weeks too. Could it be me getting used to the bass or could i have a blown sub? Also does setting the sub to a high bass setting for a couple minutes damage the sub? Sorry i'm new to these audio things.
Old Mar 18, 2003 | 07:40 PM
99_BlackSI's Avatar
Default Re: Blown subwoofer? (dxhatch93)
Well you should always keep the sub set to its closest frequency range in accordance to what amp settings are available. Setting the sub on a higher bass setting wont blow it, however it will make it sound different to you. I personally just think you have gotten used to how your sub sounds. Like I always say, when it starts to sound weak, upgrade it
Dave
Old Mar 18, 2003 | 07:44 PM
nsxxtreme's Avatar
I think you are just losing your hearing
You can damage the speaker if your high bass setting caused it to travel further than it was designed. It is hard to say with the given info. I am assuming by high bass setting you are referring to having the bass turned all the way up.
Old Mar 18, 2003 | 10:17 PM
vteg's Avatar
New User
If it is damaged you will probably have some strange noises and other things occuring.
You are just getting used to it. Get it a friend.
Old Mar 18, 2003 | 11:46 PM
super laubo's Avatar
Default Re: Blown subwoofer? (vteg)
very much true about getting used to it; however, a damaged sub sometimes show no obvious symptoms. lost in sound could be a sign of trouble coming. i'd say take it out and test the back of the subs. GOOD LUCK!!!
[Modified by super laubo, 8:46 AM 3/19/2003]
Old Mar 19, 2003 | 06:59 AM
dxhatch93's Avatar
Default Re: Blown subwoofer? (super laubo)
Thanks for all the replys guys. Super laubo what do u mean by testing the back of the sub?
Old Mar 19, 2003 | 12:17 PM
vteg's Avatar
New User
He may be saying you should check the resistance of the coils.
JohnnyEF
Audio / Security / Video
Nov 26, 2006 12:04 PM
Chubz
11
Dec 7, 2005 02:07 PM
Sleeper180sx
Apr 10, 2004 05:57 AM
Revtoredline
Apr 27, 2003 01:10 AM
civicmark
Nov 1, 2002 09:30 PM
