Correct wiring method for 0 road noise?
What is the ocrrect method to wire a audio system with no road/ground noise (whine)?
Is it RCA's and spakerwire on the right and power on the left, with the remote in the middle? Or like remote/power on the left and speaker/rca on the right?
Im talking about how you wire the wires under the carpet thru the cab to eliminate whine....
Thanks for any help!
Side of car matters and it doesn't.
Depends on how much time and effort you want to put in it.
Actually it's easier to do it the right way then the not-so-right way. If you ran your power down the drivers side it would have to cut across to the passenger side just to go thru the firewall and to the battery. Then when you're running speaker wire from the passenger side over to the drivers door you could get more interfernce then wanted.
Its just easier to pop the power thru the firewall right there at the battery on the passenger side, run it to the trunk, and keep interference at a minimal.
yah i mean i alerady have a power cable in and i wired it from the battery, across the engine bay and then in near the drivers side so i was wdonering if i could keep it as is or is it worth it to change to passenger side?
crxaddikt
Audio / Security / Video
16
Oct 23, 2003 05:43 AM
