constant power not working
Old Sep 11, 2006 | 11:34 PM
JWHATCH23's Avatar
Default constant power not working
k well i just installed my indash unit from my hatch into my teg the yellow wire on the factory harness worked before i accidentally touched 2 of the wires together and blew a fuse now i have the constant wire run to the red power wire and that is the only way it will work i cant keep my clock set or my stations pre-set is there anyway to fix this
Old Sep 12, 2006 | 04:24 AM
john666's Avatar
Default Re: constant power not working (JWHATCH23)
fuse under the hood perhaps ? on a eg its backup on a teg i dont know lol
Old Sep 12, 2006 | 06:04 AM
vicn77's Avatar
Default Re: constant power not working (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">fuse under the hood perhaps ? on a eg its backup on a teg i dont know lol</TD></TR></TABLE>
I second that, it should be fuse box under the hood. usually a 7.5
Old Sep 12, 2006 | 08:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: constant power not working (vicn77)
Ditto the above on a g3 teg it's fuse 47 -7.5A in the under hood fuse box, it may not be big enough for a lot of today's "high power" HUs, DO NOT replace with a bigger fuse, it is better to run a fused 12ga lead from the batt. to behind the HU and connect the yellow to it, [just like you would power an amp].
What is the make and model of your HU?
BTW if it's a g2, the constant power fuse is fuse 22- 10A in under dash fuse box. 94
Old Sep 12, 2006 | 07:24 PM
JWHATCH23's Avatar
Default Re: constant power not working (fcm)
thanks a lot it was the 7.5 fuse
Old Sep 12, 2006 | 10:39 PM
JWHATCH23's Avatar
k fixed my car before i fixed though tonight i was driving and my cd player cut off like 2 times and then came back on could that have been the prob. or do you think my alternator is going out **** hopefully not you gotta drop one side of the motor dont you if it does go out its not like an eg and when it cut off the check engine light came on and clock went off what you think
Old Sep 13, 2006 | 06:42 AM
fcm's Avatar
fcm
Old Fart
What is the make and model of the HU? 94
Old Sep 13, 2006 | 07:25 AM
JWHATCH23's Avatar
95 dc4
Old Sep 13, 2006 | 07:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JWHATCH23 &raquo;</TD></TR><TR><TD CLASS="quote">95 dc4</TD></TR></TABLE> HU= head unit/radio/CD player/in-dash. 94
Old Sep 13, 2006 | 08:39 PM
JWHATCH23's Avatar
SORRY CLARION NOT SURE WHAT YEAR BOUGHT FROM A FRIEND
Old Sep 14, 2006 | 09:02 AM
fcm's Avatar
fcm
Old Fart
Model number should be on the unit, [face plate maybe] 94
Old Sep 18, 2006 | 04:38 AM
raptorrage's Avatar
might want to check the power lead on the HU make sure you have a stong connection
but it sounds like its a loose connection there .
Mag00n
Audio / Security / Video
Apr 7, 2007 07:44 PM
lazyweasal4
Dec 12, 2006 04:06 PM
escape2me
Apr 26, 2006 05:34 AM
madcrossover
Jul 27, 2005 07:41 PM
_Cyclone_
Jul 17, 2005 08:06 AM
