connection for amp/antenna
Old Apr 7, 2005 | 09:45 PM
XplodeTeg's Avatar
Default connection for amp/antenna
i have a 95 integra ls and i want to somehow split the remote to amp and antenna. the problem is that the remote from the receiver was split at the driver side for amp and antenna. the connection doesn't seem to give the remote enough power. so i wonder what i should do to have a separate connection for the remote-amp and antenna itself.
Old Apr 7, 2005 | 11:47 PM
EGPrelude's Avatar
use a relay to give the remote turn on a full 12V source
85 - from the remote wire of the radio (+)
86 - ground (-)
30 - constant 12V (+)
87 - to your amp
87a - NC
Old Apr 8, 2005 | 04:51 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: (EGPrelude)
absolutely correct...
Old Apr 8, 2005 | 08:11 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGPrelude &raquo;</TD></TR><TR><TD CLASS="quote">use a relay to give the remote turn on a full 12V source
86 - ground (-)
87 - to your amp
87a - NC</TD></TR></TABLE> Or just run a wire from the acc. freepin on the fusebox to the amp and use it as the trigger, amp is only on when ign. is on, no relay needed. 94
SIC_jdm_da9
Audio / Security / Video
Apr 23, 2007 10:33 AM
97civicB18C
15
Mar 5, 2007 10:19 AM
TheTealHatch
10
Aug 24, 2006 02:15 PM
jaM3s Bond
Mar 7, 2003 03:03 PM
TeG cRaZy
Jul 1, 2001 02:03 AM
