compustar remote programming?
Old Oct 3, 2008 | 08:10 AM
chitownrida's Avatar
Default compustar remote programming?
i have an old 2w-ssr system on my car, has been working fine, i just need to replace the beatup old remote.
i have the new remote, but i cant seem to get it to learn to the system..
tried cycling the key 5 times within 7 seconds with the footbrake down.. nothing
any help would be appreciated
Old Oct 4, 2008 | 11:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: compustar remote programming? (chitownrida)
First it is 5 times within 10sec...
Remote-Pager Learn Routine and/or Adding a One Way Remote
Your Antenna Module (ANT-2WSS) has been programmed for your specific remote-pager at the time of installation. If you replace or add an additional ONE
WAY REMOTE (ANT-2WSS can be programmed for one remote-pager and 1 one- way remote), please perform the following procedure:
Step 1: Take the AA battery out from the remote-pager.
Step 2: Activate Valet/Programming mode by manually turning the ignition on and off five times with car key within a 10 second period.
The parking light will flash once with successful completion of this step.
Step 3: Within a 10 second period after cycling the ignition for the 5th time, insert the AA battery into the remote-pager.
The car parking lights will flash once to confirm that the transmitter has been programmed.
Important! Note that you can program only one remote-pager unit for a single antenna module. The new programming will erase any previous remotes that
were learned. C/O http://www.compustar.com/main.htm 94
Sashin
Jan 27, 2014 11:43 PM
BuBBa y0!
Audio / Security / Video
Jun 4, 2009 12:37 PM
Black LeX
Sep 19, 2008 07:47 AM
dad0c402
Aug 12, 2008 09:44 PM
mtbiker
Jan 24, 2002 06:42 PM
