compustar cm4000 help!!
Old Apr 18, 2007 | 05:10 PM
deejaycherub's Avatar
Default compustar cm4000 help!!
Okay. I'm in the process of installing my New Compustar CM4000. I've got everything hooked up except the remote start. I also have the omega bypass module hooked up to the honda Imobilizer. My car is a 99 honda prelude Manual. Everything works so far, doors, lock, unlock, triggers.
I am not sure how to connect the remote start wires.
http://www.velocitymotorsport....0.pdf
CN3 "connection3" is where i'm baffled
Some installer at best buy told me that I cannot hook the wires straight up to the car because the alarm is a negative alarm and my car has a positive charge. Can someone please look into this for me and explain this to me? I've look everywhere on the internet and i still haven't found an answer. Is this a stupid question? I don't know. I just don't wanna burn my car up.
where do i go from here?
Some step by step instuctions would be greatly appreciated.
-D-
Old Apr 18, 2007 | 06:24 PM
fcm's Avatar
fcm
Old Fart
Default Re: compustar cm4000 help!! (deejaycherub)
"Some installer at best buy told me that I cannot hook the wires straight up to the car because the alarm is a negative alarm and my car has a positive charge"
You misunderstood him, or he is just a complete idiot, first you do not need CN3/3, it is a relay control lead for a car that has a 2nd starter wire, [yours does not], you also do not need CN3/1,5,7, and some others depending on what options you want. 94
Old Apr 18, 2007 | 07:59 PM
trying to hook up the tach sensing wire to the injectors....but when I tap into any of the wires, the voltage seems to sit still (when increasing rpm) no matter what wire i tap into. What could be wrong?
Modified by deejaycherub at 11:22 PM 4/18/2007
Old Apr 18, 2007 | 08:18 PM
94_DC4's Avatar
Default Re: (deejaycherub)
The tach sense wire should be connected to either the thin blue wire on the distributor or the blue tach wire behind the cluster.
Old Apr 18, 2007 | 08:25 PM
Default Re: (94_DC4)
you are talking about the tach wire to the alarm for remote start right?
Old Apr 20, 2007 | 07:04 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">The tach sense wire should be connected to either the thin blue wire on the distributor or the blue tach wire behind the cluster.</TD></TR></TABLE> It can also be connected to an injector control lead, the Compustar brain is just looking for a pulse that increases with RPM, even the alt. can be used, with a pulse generator, [built into the Compustar]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deejaycherub &raquo;</TD></TR><TR><TD CLASS="quote">trying to hook up the tach sensing wire to the injectors....but when I tap into any of the wires, the voltage seems to sit still (when increasing rpm) no matter what wire i tap into. What could be wrong?</TD></TR></TABLE>Not sure what you are doing wrong, there are only 2 wires to each injector, one of them is the same color on all injectors and is DC 12V+ when ign. is in run and start, the other lead is a different color and/or tracer on each injector and is pulsed DC 12V ground control from ECU/ECM, any one of them can be used.
Once connected program tach. 94
Old Apr 21, 2007 | 11:44 AM
Civic DX 4dr's Avatar
this might help or not..
http://staub.ca/tech/Manuals/F...9.pdf
owneyboy
Jun 4, 2011 06:42 PM
93civicsedan
Audio / Security / Video
Apr 6, 2011 01:55 PM
RaWrZie
Sep 17, 2008 10:54 AM
erikiksaz1
Mar 16, 2004 04:08 PM
jetli
May 27, 2001 12:40 AM
