CompuStar 2WFM-AS
Old Jul 2, 2005 | 11:05 PM
Pure_Lude's Avatar
Default CompuStar 2WFM-AS
I was just wondering if somone knows where i can find a manual or tech support for this model of alarm
Old Jul 3, 2005 | 09:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: CompuStar 2WFM-AS (Pure_Lude)
What do you need to know? link http://www.compustar.org 94
Old Jul 3, 2005 | 09:35 AM
Pure_Lude's Avatar
Default Re: CompuStar 2WFM-AS (fcm)
well my alarm seems to be stuck in valet mode and i can't seem to be able to get it out of valet mode, It says to hold buttons 1 and 3 but nothing happens when i press them together
Old Jul 3, 2005 | 09:39 AM
Pure_Lude's Avatar
nm it's working again, but thanks for the manual tho because also when i bought the car there was no alarm manual
Old Jul 5, 2005 | 03:11 PM
Pure_Lude's Avatar
ok well i got a new problem, my battery seems to be draining like stupid, so i charged it and my alarm was stuck in valet mode so i couldn't even do anything with the alarm and i had no battery problems but i got it out of valet mode and now my battery is drained again, is this a common problem, i'll be replacing my battery today but just wondering if it's the battery or the alarm. also how do i adjust the sensitivity of my shock sensor.
Old Jul 5, 2005 | 07:47 PM
fcm's Avatar
fcm
Old Fart
It's not a common problem, unless the alarm is tripping a lot when its armed, in it's normally armed mode it draws very little power, [unless there is something wrong with it] I would check the wiring maybe, and if you have a multimeter or DVM you can check on how much draw there is on the batt when the alarm is armed. The impact sen. adjustment is right on the impact sen. itself, very small movement on the adjustment **** will make a big diff. in how sensitive it is. 94
FredHawley
Dec 8, 2017 07:04 PM
JBB93Coupe
14
Jun 16, 2009 02:11 PM
CeeJayy
Audio / Security / Video
Nov 12, 2008 06:33 PM
robble36
Jan 7, 2007 06:03 AM
Prod
Jan 13, 2004 01:29 PM
