components and mounting them
Old Jul 1, 2004 | 03:22 PM
bennihana's Avatar
Default components and mounting them
where do most people mount the crossover that comes with a component set? This is my first dealing with this and am not sure where the best place is to mount. Also do you power it off of the deck or the distrubution block i am using for the amps?
Old Jul 1, 2004 | 06:10 PM
From: eating the shit out of pizza in raleigh, NC, USA
Default Re: components and mounting them (bennihana)
in the doors, hidden, just put them in a plastic bag and tape it shut, to protect them from getting any kind of water damage
Old Jul 1, 2004 | 07:57 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennihana &raquo;</TD></TR><TR><TD CLASS="quote">where do most people mount the crossover that comes with a component set? This is my first dealing with this and am not sure where the best place is to mount. Also do you power it off of the deck or the distrubution block i am using for the amps?</TD></TR></TABLE>
If they they come with component speakers, then they are passive xovers and do not need power,[DO NOT HOOK THEM TO POWER] there is a amp input and a woofer and tweeter output, you can use the amp in deck or [better] a bigger amp, with a high pass xover in it. speaker output from amp to amp input on passive xover.
As for mounting xovers I agree put them inside the door, better to only have to run one speaker wire into door then two, but I have always been able to find enough room for them between door panel and vapor barrier,so you don't need to bag them or worry their going to get wet.
hope this helps. 94
Old Jul 2, 2004 | 11:33 AM
bennihana's Avatar
this helps some. the components are the kicker 65.2. I wasn't thinking last night when i posted that the Input + and - were for power and not speaker. I get the moron award for the day. Thanks for the input though, is appreciated
Old Jul 7, 2004 | 10:44 AM
loulax07's Avatar
Default Re: (bennihana)
In the trunk, where mine are
Easier to get to and adjust if in the trunk
I didnt like the idea of having my x-overs in my doors, prone to rattles, condensation, etc.....
Old Jul 7, 2004 | 11:17 AM
nOOber's Avatar
Default Re: (loulax07)
^ the only bad part about the trunk is running the two extra sets of wires to the mounting location.
Old Jul 7, 2004 | 11:18 AM
loulax07's Avatar
Default Re: (nOOber)
right. but isnt a problem if u know how to do it
i mean, snaking two 14awg wires isnt that bad
lube it up baby!
i went thru the existing tube in between the door and the body too
Old Jul 7, 2004 | 02:38 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loulax07 &raquo;</TD></TR><TR><TD CLASS="quote">In the trunk, where mine are
I didnt like the idea of having my x-overs in my doors, prone to rattles, condensation, etc.....</TD></TR></TABLE>
What adjustments, set it forget it, mount them between door panel and vaper barrier, [mount them] no rattles,[inside vaper barrier] no condensation. 94
Old Jul 7, 2004 | 05:40 PM
loulax07's Avatar
BLAH, looks nicer on an amp rack lol
see my www
CrazyModGSR
Audio / Security / Video
Jun 4, 2007 12:36 PM
85
Sep 15, 2006 12:29 PM
tekstyle
Feb 4, 2004 09:20 PM
