Component speaker setup.
Old Nov 23, 2006 | 08:00 PM
zerovandez's Avatar
Default Component speaker setup.
Planning to get mb quart component 6.5 inch speakers all the way aournd in my 97 civic hatchback. The speakes are rated at 70 watts rms and I plan to use a 4 channel amp at 60 watts per channel rms. I dont think I'll be using the tweeters for the rear speakers. The speakers have an option to integrate the tweeter and make it a coxial speaker. What do you guys think this setup will sound like? Decent amount of bass? I don't want a sub.
Old Nov 23, 2006 | 08:12 PM
darkspector2.0's Avatar
I think the best setup you can get without a sub is 6 x 9's what kinda car do you have?
Old Nov 23, 2006 | 08:17 PM
zerovandez's Avatar
a 97 civic hatch. I have pioneer h/u with pioneer 3way speakers all around and they sound pretty weak. I've tried all adjustments with em and just can get em to sound right. the rears are 6x9's.
Old Nov 25, 2006 | 08:47 PM
zerovandez's Avatar
planning to get the rvf216 for the front and rce269 for the rears with a 60Wx4 to power them. Your thoughts?
Old Nov 26, 2006 | 12:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: (zerovandez)
Is that a 4x60W RMS "off-board" amp, or the max HU wattage?
The front MBs are 70W continuous, the 6x9s are 50W continuous, I would be looking for a 4x75W RMS amp to drive them.
BTW, forget the tweeters in the rear, just use the woofers, tweeters in the rear will only mess up the imaging and sound stage.
FYI the MBs are not standard 6.5" speakers, [standard 6.5" speakers use a 5" mounting hole] the RVF 216 6.5" are "over-sized" 6.5" and need a 5.61" mounting hole, your Honda has a 5" mounting hole. 94
Old Nov 26, 2006 | 04:44 PM
zerovandez's Avatar
What are your recommendations? I want good bass without a sub. and the the mb 6x9 are the only component 6x9's out there that seems decent. Are the Pioneer components any good?
Old Nov 26, 2006 | 04:59 PM
fcm's Avatar
fcm
Old Fart
I drive 2 sets of Eclipse 6.5" coax, [about 7yr old] tweeters disconnected in the rear, with an Alpine CDA-7893, 4x60W, [4x27W RMS] in my 94LS, it was built as a demo car for what can be done without off-board amps or subs, [also because I wouldn't let them put anything else in as I autocross] I have been accused of having hidden amps and subs, [I do not], however extensive work was done to install the speakers. 94
Old Nov 26, 2006 | 05:06 PM
zerovandez's Avatar
The pioneer hu i have is 22w rms. I wanted to get a pioneer amp to push 60x4 continuous to a good set of speakers. I know that the front speakers are going to be hell to fit but what do you think? I can maybe use a 1inch adapter to give me more depth right? Other speakers you'd recommend besides eclipse?
Old Nov 26, 2006 | 05:36 PM
fcm's Avatar
fcm
Old Fart
Don't get me wrong, I don't think there is anything wrong with the MBs it's just IMO the Eclipse are better sounding, now if you were talking QSD 216... http://www.mbquart.com/en/produkte/car/qline/ that would be a diff. story.
I would also recommend Hertz speakers... http://www.hertzaudiovideo.com/default_en.htm
or Dynaudio speakers... http://www.dynaudio.de/eng/aut...e7358
or Morel speakers... http://www.morelhifi.com/products/mob_audio.html
All very good speakers, [not cheap] and I don't believe any of them are a direct fit into your stock speaker locations, [mods needed], keeping in mind a proper speaker install is a must for good SQ, not doing so would be a waste of money on good speakers as you will not get top performance out of them. 94
Old Nov 28, 2006 | 08:04 PM
hb420's Avatar
Bi amp your componets and get some dynamat
Old Dec 1, 2006 | 08:51 AM
zerovandez's Avatar
2 amps?
Old Dec 1, 2006 | 09:00 PM
civic_driver's Avatar
i have an mb quart 2400 reference amplifer 2 channels for sale. 2x200watts rms @ 4ohms, 2x400watts rms @ 2ohms, 1x800watts rms @ 4ohms in bridged mode. check it out the link in my siggy
Old Dec 2, 2006 | 03:07 PM
hb420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">2 amps?</TD></TR></TABLE>
nope. use all 4 channels on the amp just for the componets. Two channels for the woofers and two channels for the tweeters. And run your rears off the deck. Just loud enough for people in the back to hear.
Old Dec 5, 2006 | 07:32 PM
zerovandez's Avatar
wow never heard of a setup like that....
Old Dec 6, 2006 | 01:07 PM
EBP_SI's Avatar
Default Re: (hb420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb420 &raquo;</TD></TR><TR><TD CLASS="quote">
nope. use all 4 channels on the amp just for the componets. Two channels for the woofers and two channels for the tweeters. And run your rears off the deck. Just loud enough for people in the back to hear.</TD></TR></TABLE>
you would need some form of an active crossover or a set of components that can be passively biamped. otherwise you're best option would be to bridge your 4 channel amp and use one channel for left and one channel for right.
Old Dec 6, 2006 | 05:26 PM
zerovandez's Avatar
So why not power all 4 speakers with the amp? Why power only the front 2?
Old Dec 6, 2006 | 05:57 PM
hb420's Avatar
Default Re: (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
you would need some form of an active crossover or a set of components that can be passively biamped. otherwise you're best option would be to bridge your 4 channel amp and use one channel for left and one channel for right.</TD></TR></TABLE>
You can do that with mb quart crossovers. That's how my setup is ran. They have dual imputs on them. You could just bridge them to but the other way you get more adjustability.
miksew
Audio / Security / Video
15
Jul 28, 2005 09:31 AM
okman16
Oct 11, 2003 09:10 PM
Revtoredline
Apr 27, 2003 01:10 AM
ilikemyaccord
Apr 15, 2003 10:11 PM
deceit
May 13, 2002 06:12 PM
