clock & radio resets everytime
Old Oct 16, 2003 | 11:07 AM
integra*RS*'s Avatar
New User
Default radio resets-->fixed
My clock & radio resets everytime I turn off & turn on the car. I believe I am having problems with the ground wire(black), power(red), & 12voltwire(yellow). Any help would be appreciated coz this sux.......not having the clock right & losing all the presets. Thanks in advance.
-Jun
Modified by integra*RS* at 10:12 PM 10/19/2003
Old Oct 16, 2003 | 11:11 AM
acuradriva's Avatar
Default Re: clock & radio resets everytime (integra*RS*)
check the thing that is in common with the clock and the radio... the fuse. i think that 1 is under the hood.
Old Oct 16, 2003 | 11:14 AM
New User
Default Re: clock & radio resets everytime (acuradriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuradriva &raquo;</TD></TR><TR><TD CLASS="quote">check the thing that is in common with the clock and the radio... the fuse. i think that 1 is under the hood.</TD></TR></TABLE>
So the fuse might be blown?.....i'm goin to check later tonite, if not it, any other suggestions.
Old Oct 16, 2003 | 01:14 PM
rjr162's Avatar
it's going to be your constant wire most likely... unless you have done like some people and hooked your ground to the Illum wire. If you do, it will work fine and remember the stations correctly until you have your lights on.. and then the radio won't function at all
Old Oct 16, 2003 | 06:24 PM
Xazzu's Avatar
my radio wouldn't even turn on if it didn't have the proper constant wire in, but that's worth a check. that and the fuse. what everyone else said
Old Oct 16, 2003 | 10:55 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
I'll bet you that the radio's constant Yellow and accessory Red wire are twisted together and hooked up to the vehicle's accessory output wire.
Old Oct 17, 2003 | 01:56 AM
muse's Avatar
Default Re: clock & radio resets everytime (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">I'll bet you that the radio's constant Yellow and accessory Red wire are twisted together and hooked up to the vehicle's accessory output wire.</TD></TR></TABLE>
Yup. If not, try switching your two positive wires. one is 12v constant (memory) the other is 12v Ignition (only on when key is on).
Old Oct 17, 2003 | 08:19 AM
New User
I had to switch those to because the only way to have it turn on.....actually they are twisted together.......only way i can turn on the radio
"Yup. If not, try switching your two positive wires. one is 12v constant (memory) the other is 12v Ignition (only on when key is on"
What positive wires......12v constant is yellow? n 12v ignition is what color?
n now my radio won't even turn on if I dont have the light on....not all the way, just so that the bumper lights are on n not the headlights.....if i turn it off....the radio turns off too. This sux.......need help
I think my ground wires for the whole car is f'd up......
Also, does anybbody have any amp for sale ...2channel
Old Oct 18, 2003 | 11:15 PM
New User
help
Old Oct 19, 2003 | 05:55 AM
rjr162's Avatar
ok, either you connected a power wire to the Illumination, or your ground isn't connected to the correct wire (maybe to the dimmer). Just connect the black ground wire to a bolt in the dash area. Then you'll know what you're left with. My guess is you incorrectly connected the red accessory wire.
Old Oct 19, 2003 | 09:39 AM
New User
Default Re: clock & radio resets everytime (rjr162)
then what do i do with the black wire that comes the car......if i connect the black wire from the stereo to a bolt
Old Oct 19, 2003 | 01:09 PM
Xazzu's Avatar
nothing, it's just meant as somewhere to ground the stereo, you can stuff it back
Old Oct 19, 2003 | 06:12 PM
New User
Default Re: clock & radio resets everytime (Xazzu)
Thanks for the help everyone......it's all fixed
Only problem now is:
How do you get a Double deck stereo to fit an integra.....I cut out the middle part but does anybody know a place where I can get an installation kit
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
91EF_Si
Dec 23, 2007 08:44 AM
SumOne
Oct 15, 2006 07:32 PM
picasso1
12
Sep 20, 2006 11:22 AM
doggworld1233
Jun 17, 2006 04:32 PM
