Clifford Super Nova II removal help
Old 08-16-2004, 12:29 AM
Drakko's Avatar
Default Clifford Super Nova II removal help
I have a Clifford Super Nova II alarm installed a long, long time ago. It is broken. It won't unlock doors, will go crazy out of the blue, and will only behave somewhat in valet mode. Clifford website sucks when it comes to support. They only posts the manual (which I still have) and not the wiring specifications, etc. Anyone knows how I can remove the brain to return my car to its original state before the alarm installation? Anything?
Old 08-16-2004, 08:16 AM
Rev_Auto's Avatar
Default Re: Clifford Super Nova II removal help (Drakko)
Depending on how it was installed it could be as easy as removing some t taps. You main concern should be the starter interupt that should have been installed. Basically you eill need to reconnect those wires back together with a but connector or solder it and tape it.
If you do not feel comfortable with doing this yourself take it to a shop and have it done. Some shops that will remove what they install for free.
I know this sounds easy but I also have 11 years experience doing it. It is not hard but it should be done right otherwise your car may not start.
Old 08-16-2004, 05:19 PM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drakko &raquo;</TD></TR><TR><TD CLASS="quote">I have a Clifford Super Nova II alarm installed a long, long time ago. It is broken. It won't unlock doors, will go crazy out of the blue, and will only behave somewhat in valet mode. Clifford website sucks when it comes to support. They only posts the manual (which I still have) and not the wiring specifications, etc. Anyone knows how I can remove the brain to return my car to its original state before the alarm installation? Anything?
</TD></TR></TABLE> 1- find alarm brain
2- remove alarm brain,[unplug]
3- one by one follow each wire from alarm brain to where it is connected, remove and repair OEM wire, [elec.tape and a wiretye]
4- remove impact sen.,siren,LED,override switch and there wiring.
And as Rev_Auto said if you have startercut installed you will have to remove a relay, you will find the relay at the end of one of the wires from the alarm plug/s, you will have to rejoin the starter wires to each other once you remove the relay,[black/white most Hondas] that is best done by soldering. 94
davidzhou4893
Audio / Security / Video
01-26-2015 06:31 AM
NerfGunner420
07-05-2014 09:34 PM
Knight1
09-24-2005 01:16 PM
jason190
03-10-2005 08:38 PM
mickey513
06-04-2003 07:08 AM
Quick Reply: Clifford Super Nova II removal help
