cigarette lighter kill switch
Old Nov 3, 2009 | 08:32 AM
  #26
TypeRfit's Avatar
RESIDENT
Default Re: cigarette lighter kill switch
You can use any switch really, mine was my cruise control button, but the main ? is what do you want it to cut, i.e fuel, starter, ignition? I had mine set up for ignition, if you want to make it easier just go to autozone (or your local repair shop) and pick up a toggle switch, one way is on and one way is off.
Old Nov 3, 2009 | 10:24 AM
  #27
crazyboy's Avatar
is there any way to make my cigarette lighter work too? i have a gps that i use the cigarette lighter for. and i dont want to do a toggle switch because i want all the switches within my reach and not noticable to the naked eye
Old Nov 3, 2009 | 10:40 AM
  #28
nsxxtreme's Avatar
Yes, use a low resistance resistor say .05 ohms in series with the power lead. As current flows through the resistor it causes a voltage drop on the other side. Use a schmitt trigger to sense the change in voltage (Look it up http://en.wikipedia.org/wiki/Schmitt_trigger ) to trigger your relay. A little beyond the basic do it yourself setup but entirely possible and relatively cheap (maybe $2 in parts). It really is a very basic circuit but depends on your skill level.
Old Nov 4, 2009 | 12:53 AM
  #29
crazyboy's Avatar
well i just solved the problem. i completed the cigarette lighter kill switch and i went to walmart and they had a y adaptor tp convert 1 cigarette lighter into two, i extended the wires and mounted them in the glove box. pics tomorrow if anyones interested in seeing
Old Nov 4, 2009 | 11:46 AM
  #30
crazyboy's Avatar
my "dummy lighter"
where my new car cigarette lighters are located
let me know what you guys think!
Old Nov 4, 2009 | 12:26 PM
  #31
teggi's Avatar
that looks clean....lil dirty but clean
Old Nov 4, 2009 | 12:38 PM
  #32
nsxxtreme's Avatar
why not move your cigarette lighter switch to your glove box and leave the factory lighter working as normal? Then you dont have to open and close your glove box or have wires comming out of it for your devices.
Old Nov 4, 2009 | 01:39 PM
  #33
XstreamRocker's Avatar
I think it would have made more sense to put the kill switch in the glove box, but that's just my opinion...
Old Nov 4, 2009 | 06:50 PM
  #34
crazyboy's Avatar
ok well my reason for the setup is the only things i need to charge are my gps and ipod and i dont use it all the time, so instead of opening my glovebox pushing the lighter in, starting the car, pulling the lighter out, and closing the glove box EVERYTIME i want to drive somewhere. i have it set up so i only have to do that when i need something charged. plus i think someone would see me opening the glove box starting my car and closing it again
Old Nov 6, 2009 | 07:07 AM
  #35
TypeRfit's Avatar
RESIDENT
Ditto
Old Nov 6, 2009 | 08:58 AM
  #36
crazyboy's Avatar
ha thanx. its only dirty cuz its been down for like a week and a half. but its up and running and better yet clean now lol
Old Nov 6, 2009 | 12:04 PM
  #37
teggi's Avatar
ha kewl
i think i might use this lil trick too
Old Nov 6, 2009 | 08:51 PM
  #38
tmzcivic's Avatar
Can anyone help me wire a fuel cut using the AC button on my climate control?
Its a 1994 Civic HB. I would like the car to run if the AC button is on(lit), and fuel cut if the button is off (unlit).
I would love some specific instructions as I had my dash completely apart and was unable to make it work!
PM me if you can assist me
Old Nov 6, 2009 | 11:25 PM
  #39
cstone's Avatar
you'll get better response if you make your own thread for this
Old Nov 7, 2009 | 01:05 PM
  #40
teggi's Avatar
yep^^^
if i was you i would figure out (on the AC) which wire is ground and which is positive then do the same for da fuel pump
integra_101
Jul 29, 2014 07:25 AM
Dazer 1991
Aug 27, 2012 03:26 PM
a1320addict
Audio / Security / Video
Feb 8, 2006 09:59 AM
my_slow_civic
12
May 9, 2005 07:08 PM
X2BOARD
Apr 21, 2004 09:24 AM
