Charging Stinger battery
Old Sep 26, 2003 | 08:55 AM
ricodemus's Avatar
Default Charging Stinger battery
Ok, hopefully some of you work in audio. I have the SP-800 Stinger battery and it died. They say I need a charger that can do 50A for 3+ hours. None of the auto stores around here know what kind of chargers they have. Stinger says a "Trickle" charger will not work and ruin the battery. I'm trying to find what kind of place has this charger, or if anyone has experience charging these batteries.
Old Sep 26, 2003 | 09:05 AM
ricodemus's Avatar
Default Re: Charging Stinger battery (ricodemus)
Nevermind, my buddy boostedcivicsir has a charger at his shop that can do it. Wheeee thanks Mikey!
Old Sep 26, 2003 | 05:43 PM
nsxxtreme's Avatar
Yes basically you need a charger that's capable of supplying a higher voltage than normal. It took me two weeks of charging to bring mine back to life after it sat for a year. Works great now though.
Old Sep 26, 2003 | 06:20 PM
vteg's Avatar
New User
A road trip will take care of this problem. It will just cost you gas.
Old Sep 27, 2003 | 09:49 AM
nsxxtreme's Avatar
Default Re: Charging Stinger battery (vteg)
I tried that it doesn't work.
Old Sep 27, 2003 | 07:42 PM
vteg's Avatar
New User
Default Re: Charging Stinger battery (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">I tried that it doesn't work.</TD></TR></TABLE>
I wonder why not? The alternator should be able to provide more than 50 amps. I have never had to use a charger for a battery to get it back, but then there are always exceptions to everything.
Old Sep 28, 2003 | 01:49 AM
nsxxtreme's Avatar
It's because the voltage drops to low, around 8 volts. You need higher than 14 volts to bring it back to life. The internal resistance in the battery becomes so high that the 14 volts doesn't really do anything. You need a higher voltage so that you are actually passing some current into the battery.
Old Sep 28, 2003 | 02:02 AM
vteg's Avatar
New User
Ok, that makes lots of sense. Normal dead batteries are in the 10 volt range. ESR would be a bitch at 8 volts I did not know deep cycles got down that low.
Old Sep 28, 2003 | 03:16 AM
nsxxtreme's Avatar
It may have been close to 9 but still in the 8's. I just remember it being way below 10. It sat for a year unused. The stinger battery is a dry cell. Its a great battery IMO and worth the money.
91akira
Oct 21, 2008 06:29 AM
H22CD7
Audio / Security / Video
16
Jan 16, 2007 08:17 AM
DocSean
Honda Motorcycles
Apr 19, 2005 08:14 PM
JDMvtecDRAGSTA
13
Mar 7, 2004 10:38 PM
LudemanDan
Aug 29, 2003 07:53 PM
