charging capacitor
Old Jul 29, 2008 | 12:26 PM
zsudz922's Avatar
Default charging capacitor
im charging my 2f hybrid rockford fosgate cap and its taking a long time. how long is it supposed to take? im using a 12v battery charger at 12v 15amp.
Old Jul 29, 2008 | 04:20 PM
02 accord's Avatar
Default Re: charging capacitor (zsudz922)
Lol. That's not how you do it. Hook up the ground to the cap, then hook up a 20 watt light bulb in series with the power. The bulb will glow brightly at first, and then slowly fade. When it's very dim/off, remove the bulb and connect the power wire directly to the cap.
What I find easiest to do is connect the amp/cap as it should be (with the power wire fuse removed). Then connect a light bulb where the fuse goes. When the bulb goes out, remove the bulb and install the fuse.
Old Jul 29, 2008 | 05:32 PM
fcm's Avatar
fcm
Old Fart
Ditto all the above^^^. 94
Old Jul 29, 2008 | 07:15 PM
zsudz922's Avatar
Default Re: charging capacitor (fcm)
mine cam with a little chip with an led on it so i didnt have to do that.
so i called the guy at RF and he said to watch the volt readout on the cap and wait till its about 10v then hurry up and install it. i ended up turning the charger to 110amp instead of 15amp, then the volt start rising on the camp readout. i did that then installed it as fast as i could. worked out good. thanks
scanlous_styles
Audio / Security / Video
Nov 29, 2007 08:58 PM
TekBuDDy
Feb 14, 2007 10:41 AM
89hbcivicguy
Sep 3, 2005 08:33 AM
R Thizzel
17
Nov 22, 2004 05:48 PM
shauniewalnuts
13
Jan 21, 2004 05:15 PM
