Capicator
Old Nov 29, 2007 | 08:13 PM
scanlous_styles's Avatar
Default Capicator
how do i install a capicator?
Old Nov 29, 2007 | 08:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: Capicator (scanlous_styles)
Remove fuse in amps power lead, connect the amps power lead to the caps pos.(+) terminal, connect a lead, same [gauge] from caps pos.(+) terminal to amp, ["parallel" connection] run a ground lead, [same gauge or thicker then the power lead] from the caps neg. (-) terminal and ground it at the same place the amp is grounded.
Once connections are made, install a 12V light bulb, [in series] where the fuse goes, the bulb will light up bright and slowly dim down till it is almost out, once almost out, the cap is charged, remove bulb and install fuse. 94
Old Nov 29, 2007 | 08:58 PM
Default Re: Capicator (fcm)
thanks dude!
zsudz922
Audio / Security / Video
Jul 29, 2008 07:15 PM
muhaMan
Aug 12, 2007 09:33 PM
89hbcivicguy
Sep 3, 2005 08:33 AM
Daniel_san
May 5, 2004 01:22 PM
cd5_2NR
Mar 12, 2003 06:34 PM
