cda-9835 install
Old Nov 12, 2004 | 04:03 AM
skellator_thoj's Avatar
Default cda-9835 install
Well I just recently got my alpine cda-9835 hu installed from circuit city, and it sounds like ****..speakers distorting..not sure why..checked out the speakers and it wasn't blown..so i'm confused..the speakers are infinity reference 5.25..and i thought that for the hu..i had to run a 10-gauge amp wire to the hu..so I was wondering if anyone knew how it was suppose to be..so plz give me advice!! TIA..
Old Nov 12, 2004 | 08:19 AM
Default Re: cda-9835 install (skellator_thoj)
ttt
Old Nov 12, 2004 | 10:30 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skellator_thoj &raquo;</TD></TR><TR><TD CLASS="quote">Well I just recently got my alpine cda-9835 hu installed from circuit city, and it sounds like ****..speakers distorting..not sure why..checked out the speakers and it wasn't blown..so i'm confused..the speakers are infinity reference 5.25..and i thought that for the hu..i had to run a 10-gauge amp wire to the hu..so I was wondering if anyone knew how it was suppose to be..so plz give me advice!! TIA..</TD></TR></TABLE>
Not only does this hu require a fused power source also this unit must be grounded as well. Do you have a clean ground?
Old Nov 12, 2004 | 11:10 AM
kgoroway's Avatar
Sorry to hijack, but does it require a fused power source if you don't plan to use the built in amp?
Old Nov 12, 2004 | 11:15 AM
Default Re: cda-9835 install (Tweekerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">
Not only does this hu require a fused power source also this unit must be grounded as well. Do you have a clean ground?</TD></TR></TABLE>
i have no idea..circuit city did all the work..
Old Nov 12, 2004 | 11:46 AM
kontai69's Avatar
Default Re: (kgoroway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kgoroway &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to hijack, but does it require a fused power source if you don't plan to use the built in amp?</TD></TR></TABLE>
No.
Old Nov 12, 2004 | 11:47 AM
kontai69's Avatar
i have no idea..circuit city did all the work..</TD></TR></TABLE>
If this is the case, just take it back to them and demand that they resolve the problem.
Old Nov 12, 2004 | 12:04 PM
Default Re: cda-9835 install (kontai69)
do you think the speakers are blown..
Old Nov 12, 2004 | 12:08 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skellator_thoj &raquo;</TD></TR><TR><TD CLASS="quote">do you think the speakers are blown..</TD></TR></TABLE>
are you experiencing similar distortion in the rears? If so than i doubt all 4 speakers are blown problem may be hardware or install related. If not, than you could have an issue with the fronts.
Old Nov 12, 2004 | 12:10 PM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kontai69 &raquo;</TD></TR><TR><TD CLASS="quote">
If this is the case, just take it back to them and demand that they resolve the problem.</TD></TR></TABLE>
agreed. if you purchased the hu and had it installed by CC, then yes, take it back and demand a resolution.
Old Nov 13, 2004 | 07:53 AM
i have no rears..just the fronts..there the 5.25 infinity reference 2-way speakers..not components..
Old Nov 13, 2004 | 02:01 PM
type Gendy's Avatar
CAn you swap in another set of speakers to test it? EXtra set kcicking around? borrow a buddies?
If i was you i'd take it back to circuit shitty. I'm going to buy a deck this week, probably from them, and they have that free install promo. I really dont want anybody touching my car, but i'm half considering it just if a problem came up they coudlnt argue that i did the install and voided a warranty or some ****?
Old Nov 13, 2004 | 06:31 PM
dc24me's Avatar
do you have a subwoofer?
how loud do you listen to your music?
what music do you listen to?
are the speakers properly installed without any leaks around the basket and the factory cutout?
is the media expander on?
what built in eq preset are you using?
to get the most out of the V-drive 60x4max or 26x4 rms you need to connect the constant power (yellow) directly to the fusebox or battery of the car and ground (black wire) directly to the chassis. 10g wire is overkill imo. i'd just take a couple of 18g primary wires and double them up by twisting them on a drill.
any decent shop will charge extra to do this because it takes extra time to do it right. Even though it's suggested in the manual to do this, it's not necessary when you are not using the built in amp.
Old Nov 14, 2004 | 06:16 AM
Default Re: cda-9835 install (dc24me)
how do i burn my i-personize settings to a cd-r disc?? do i burn in data or audio music?? using nero to burn it..plz help!!
Old Nov 14, 2004 | 05:50 PM
tweekerz's Avatar
http://www.alpine-usa.com/
Click on the link for i-personalize.
Old Nov 16, 2004 | 12:04 AM
fried's Avatar
hey dude... if the shop has installed the headunit properly ie all wires etc right, then it should be fine.
i think what YOU need to do, is read the manual, go to alpine site, learn about all the settings, and play wiht ur headunit.
the 9835 is a highend unit, which comes with personalized eq settings, crossover settingsd and time correction. most likely its ur crozzover settings that are making ur speakers distort.
5.25" speakers are not going to be able to handle bass notes. its just not physically possibly. so while the speaker is playing full range (ie the cross over filter is off) its going to distort prematurely purely because its trying to play bass notes, and it cant.
read up in ur manual about the crossover settings, and change them to high pass filter slope. that way, ur speakers will filter out the bass notes. u'll be able to get alot more volume out of ur speakers. the processor and amp in the 9835 is quite good, so it should be sufficient for now.
Old Nov 16, 2004 | 12:06 AM
fried's Avatar
oh... and if u want bass, ur either going to have to get bigger speakers, like 6x9s in the rear, or a sub, OR just not listen to your music loud mate.
its a tradeoff.
Old Nov 16, 2004 | 02:42 PM
Default Re: (Alphax)
how would i set it to 2way??
Old Nov 16, 2004 | 04:09 PM
FireMedic's Avatar
Default Re: (skellator_thoj)
CircuitCity offers a lifetime warranty on their install, so if something isn't right with their installation, they have to fix it, if someone in the RoadShop disagree's, ask to speak to the Sales & Installation Manager. If you want, you can take it back to a different RoadShop location since CircuitCity warranties their products and installation at all locations. If they disagree, ask to speak to the store manager. Also, if you're not completely satisfied with their install within 30 days, you can take it back for a refund. Just a word of advice. Thanks!
Old Nov 16, 2004 | 11:08 PM
fried's Avatar
u still havent read ur manual have you? LOL
manuals are there for a reason. it will tell you exactly how to change it between 3way and 2way.
on the bottum of the actual headunit are a couple of switches. one of them changes between 2way and 3way.
have a look
Old Nov 17, 2004 | 07:33 AM
PM-Performance's Avatar
you DONT need the fused power. i didnt do a larger gauge for mine yet. But its all in the settings. I havent has time to play with the EQ settings, but its all in that. Best thing to do is load your own custom settings onto it from the Alpine site and go from there. Mine does the same **** , just too much highs and too much lows on the preset settings.
The 2 wya and 3 way only matter for when you are using thre preouts correct?
Old Nov 17, 2004 | 12:06 PM
civic_speed99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">
A guy at a local shop told me not to even bother to hook up the main ground and power wire, but just to use the harness. Could this be why my speakers seem distorted slightly at low volumes, and lack anykind of bass. ANd i have pioneer 3ways all around.
Sorry to steal the post. Related Problem
Old Nov 17, 2004 | 12:39 PM
Default Re: cda-9835 install (civic_speed99)
no , its in the settings.
Old Nov 17, 2004 | 03:09 PM
tweekerz's Avatar
Default Re: cda-9835 install (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you DONT need the fused power.
Then why would Alpine ask to have it done?
Of course you can use the harness but to get the full performance out of the HU it requires a fused power and solid ground. &lt;-- per Alpine tech
Old Nov 17, 2004 | 04:59 PM
you are asking about your mids and highs breaking up , that is not becuase of not running a fused power. Think people. Your **** is breaking up becuase because the settings are off. If you used the presets then i can understand it. Mine are doing the same becuase i havent played with it yet. But how can you tell me your speakers are breaking up and distorting from not running a fused thicker power? Thats retarded. Yes it will help for more power and flow, but the more power isnt going to make them sound better if they are already breaking up. I just dont understand anyones logic here. Everyone is too set on Tech said this, rather than using common sense.
