CD Changer HELP needed
Old Jul 10, 2005 | 03:20 PM
Stockton's Avatar
Default CD Changer HELP needed
I have a '98 Jetta GLX with the Bose stereo.(I tried vwvortex but no one ever replies)
The oem cd changer is almost dead and I want to replace just the changer.
On Crutchfield the only 2 replacements it lists say one is for the changer with the round 13 pin connecter and the other is for a rectangular connecter.
My OEM Bose changer is an 9 pin.
Does anyone know a changer that I can use to replace mine or is there an adapter I can use to connect it to the 13 pin one?
http://www.crutchfield.com/S-f...0&t=0
Those are the 2 that crutchfield shows will fit my car by make and model but like I said mine has an 9 pin round connecter.
Any info will be great I don't know alot about car audio I just want a working cd changer that will read burned cds. I don't want to have to replace the headunit either.
I have heard that I can't replace the head unit without replacing the speakers cause the Bose system speakers all work on a different ohm frequency or something and they'll blow easily with a non Bose head unit.
Old Jul 10, 2005 | 03:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: CD Changer HELP needed (Stockton)
Go to http://www.staub.ca and check PAC, Blitzsafe or Soundgate, one of them should have what you need 94
Old Jul 10, 2005 | 03:58 PM
Stockton's Avatar
Default Re: CD Changer HELP needed (fcm)
Thanks I found this: http://www.blitzsafe.com/blitz....html
But I don't know what it is. It says for for the 8pin connecter in the trunk, but what does it convert it to, what kind of changer can I then plug into it.
Sites kinda vague and I don't know much about this stuff.
I also found all these things https://www.soundgate.com//ind...d=167&
But for some reason when I click on 'Does it fit my car?' link I'm missing some font in my adobe reader and it won't open correctly. They seem expensive to just for an adapter.
Old Jul 11, 2005 | 09:35 AM
fcm's Avatar
fcm
Old Fart
The Blitzsafe is for the Panasonic DP-601 and DP-610.
The Soundgate is for, [according to their application guide] non Bose systems.
Old Jul 11, 2005 | 03:34 PM
Stockton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">The Blitzsafe is for the Panasonic DP-601 and DP-610.
The Soundgate is for, [according to their application guide] non Bose systems. </TD></TR></TABLE>
Hmm, ok.
Is the panasonic you mentioned what I have in there now or is that what I replace the oem with?
I googled but couldn't find any panasonic changers with that model number.
Old Jul 12, 2005 | 06:58 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stockton &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm, ok.
Is the Panasonic you mentioned what I have in there now or is that what I replace the oem with?
I googled but couldn't find any Panasonic changers with that model number.</TD></TR></TABLE>It is what you replace it with, the oem changer may be a Panasonic.
VW used both Panasonic and Clarion sound systems and the "Bose" system in your car is probably using a Panasonic changer, the plugs are just different 94
PS when I Google Panasonic DP601 multi disk cd changer I get 65 sited, even found one that has a VW Jetta changer, http://www.auction-best-choice.com 94
Modified by fcm at 11:54 AM 7/13/2005
Old Jul 13, 2005 | 09:50 AM
Stockton's Avatar
I swear I don't know what is wrong with me but I can't find a single Panasonic DP601 for sale.
I get hits from google when I search it but it's just info or adapters, I can't find the actual changer anywhere.
Old Jul 13, 2005 | 10:24 AM
Stockton's Avatar
I wrote crutchfield and they said no cd changer is compatible with the Bose system.
They said I can use some FM Modulator changer.
http://www.crutchfield.com/S-m...ore=0
Anyone know anything about these?
Old Jul 13, 2005 | 11:20 AM
fcm's Avatar
fcm
Old Fart
http://rtgrim.com/store/cxdp601.html try here 94
Old Jul 13, 2005 | 11:31 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stockton &raquo;</TD></TR><TR><TD CLASS="quote">I wrote crutchfield and they said no cd changer is compatible with the Bose system.
Anyone know anything about these?</TD></TR></TABLE> They should have said, we do not sell what you need, Blitzsafe has the adpt. that you need to use a Panasonic changer.
When you use a FM mod. to get the signal into a HU, the SQ will suck, no better the listening to the radio, except the radio station follows you, you will never be out of range. 94
Old Jul 13, 2005 | 11:54 AM
fcm's Avatar
fcm
Old Fart
Anyone know anything about these?</TD></TR></TABLE> FM modulator changers SQ is very poor, no better the the radio 94
Old Jul 13, 2005 | 12:19 PM
Stockton's Avatar
Damn $235 for the changer.
Thanks alot for just finding it for me. I was looking up the wrong number I guess, I wasn't putting the CX infont of it, I was just searching for DP601.
What's the difference between the 601 and the 610 cause I can find them both now with the full the part number.
Also is true since it's Bose if I just wanted to replace the headunit I would need to replace the speakers too?
I would really rather just change the head unit to something with MP3 compatibility if I don't have to change all the speakers out.
Old Jul 13, 2005 | 12:30 PM
Stockton's Avatar
I found this, it's the 610:
http://rtgrim.com/store/cxdp610.html
But says it needs the VWPILD adapter and that cost's another $100.
http://www.thecarstereo.com/pr...01625
Is that the same adapter from blitzsafe?
And any idea how much that costs?
Old Jul 13, 2005 | 12:44 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stockton &raquo;</TD></TR><TR><TD CLASS="quote">Damn $235 for the changer.
I would really rather just change the head unit to something with MP3 compatibility if I don't have to change all the speakers out.</TD></TR></TABLE> Yea $235 plus the adpt. probably another $50, I also made the same mistake with the model number, couldn't figure out why I couldn't find the sites I found yesterday, so I went to http://www.panasonic.com and got the P/N there, the 601 is a 6 disc and the 610 is a 10 disc.
As for the Bose system, I am not sure for the VW, but PAC, Blitzsafe, Soundgate and others make "Bose" adpt. for aftermarket HU, and if your VW uses a single Bose amp instead of an amp on each speaker, then the speakers are probably 4 ohm, so you would not have to change the speakers, just rewire them the the aftermarket HU 94
Old Jul 13, 2005 | 01:09 PM
Stockton's Avatar
Yea, it's a single amp under the trunk deck.
When you say rewire the speakers do you mean I would run new wires to each one from the head unit?
Or could I just bypass the amp somehow?
Old Jul 13, 2005 | 01:19 PM
fcm's Avatar
fcm
Old Fart
You may be able to bypass the amp, as long as there are 8 wires for speakers at the Hu running to the amp, you could just connect the speaker inputs to the amp to the speaker outputs of the amp. 94
bdavis
Aug 3, 2006 06:52 PM
03civda
Audio / Security / Video
13
May 24, 2006 05:41 PM
vinuneuro
May 21, 2006 04:34 PM
hobo79
Oct 6, 2001 03:14 PM
