CD Changer Connector
Old Sep 30, 2005 | 09:43 PM
az1324's Avatar
Default CD Changer Connector
Does anyone know the part number (manufacturer not honda) of the blue 14-pin rectangular CD Changer connector on the headunit of most 1998+ vehicles??
Old Oct 1, 2005 | 05:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: CD Changer Connector (az1324)
What is it you want to do? 94
Old Oct 1, 2005 | 09:08 PM
az1324's Avatar
Default Re: CD Changer Connector (fcm)
I need to make some cables that plug into the CD changer port. I need a bunch of them.
Old Oct 2, 2005 | 08:08 AM
fcm's Avatar
fcm
Old Fart
The only ones I know of that have a separate cable/plug and "handshake unit" is SoundGate, and you would have to check with them to see if you can just get the cable/plug without the "handshake unit", I can't see why not, as the "handshake unit" will be the same for a number of cars, and only the cable/plug changes.
https://www.soundgate.com//ind...rer=1 you can check here.
The other thing you can do is go to an electronics supply store and just buy the raw plug and make your own, the plug is not a Honda only it will be an Amp or Molex, something like this....
http://www.molex.com/cgi-bin/b...ction of coarse there are more then two plug manufactures, all you have to do is find an electronics store that sells the one you need.
http://www.amp.com/ good luck 94
Old Oct 2, 2005 | 12:02 PM
az1324's Avatar
Yeah I was just hoping someone had done that already and found the manufacturer and part number.
Old Oct 3, 2005 | 06:46 PM
az1324's Avatar
hopeful bump
black0hatch
Honda CR-V & Element
Nov 25, 2012 04:18 PM
Radim
Audio / Security / Video
10
Nov 28, 2010 06:41 PM
nightscream
Oct 2, 2009 05:54 AM
.Kevin.
Jun 27, 2006 05:14 PM
